Zigbee Interrupter 1 2 3 4 6 Gangs Light Switch Brazilian Wall Switches Work with Tuya Smart Life Alexa Google Home
Zemismart Zigbee Interrupter 1 2 3 4 6 Gangs Light Switch Brazilian Wall switches Work with Tuya Smart Life Alexa Google Home
Note Before Order:
- the TB26-4 four gangs switch and TB26-6 six gangs switch cannot work with Homekit !!!
- Tuya Zigbee Hub is required.
Feature:
- Tuya APP 【Multi-Control Association Function】
New Function for our zigbee switch is Multi-Control Association, it allows to control one light by multiple switches. This function is more convenient for the zigbee switch, can control one light by 2 switches or multiple switches on Tuya.
- High Quality Physical Push Button Design:
High-quality and luxury design with Big physical button for push control. You can install it in your bedroom or living room. If the zigbee central control is far away, and you can install a zigbee switch in the middle, it will extend the signal of the zigbee central control by a few meters.
- Tuya Zigbee Smart Wall Light Switch:
This Zigbee smart light switch is a perfect alternative option for traditional lighting system. It is designed in the size of US standard wall mount light switch, comes with all accessories you need to replace an existing wall switch.
- Voice & Timer Control:
Smart Light Switch for Alexa and Google Home, activates the on/off button with voice commands, making life easier. Set up a schedule or timer on/off your lights on night, and then your will never go back to a dark house when you go back home after working.
- App Remote Control:
Smart Home Light Switches can be controlled remotely using your phone, and devices connected with switches can work independently. Even if you are not at home, you can use the mobile app to remotely control the device from anywhere and control the lights on/off at any time.
TB26-4
TB26-6
