About this item
  • • Advanced Leak Detectionwith Latest Z-Wave 800 series
  • • Equipped with a temperature sensorto detect leaks, burst pipes, and overflows—alerts you before major damage occurs
  • • Receive instant notifications on your phone,even when away from home
3 Kits already found their owners
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
Remote Access Included
Yes Usually a monthly plan
Ezlo Z-Wave Smart Water Shut-Off Valve Kit
Stop a leak before it becomes a flood
Ball valve included
Pick the size of your main water line. No Z-Wave hub yet? Add Ezlo Plus for $125
Ezlo Plus $125$179.95SAVE 31%
We recommend professional valve sizing and installation!
Ball valve
Total $374.95
Dimensions:
Power:
Voltage: 110 VAC converted to 24V DC (Class 2 power converter with 20’ cord, 1.3A full load)
Materials:
Z-Wave module:
Compatibility:
A Z-Wave hub is required
Works with Ezlo Z-Wave hub
Usage:
FCCCERoHSULWEEEZ-Wave Plus
Ezlo Z-Wave Flood Sensor
Dimensions:
Main body: 68 mm(W)*22mm(H),
Extension probe: 50 mm(W)*5mm(H),
Wire: 1000mm(L)
Power Supply:
ER14250 3.6V Battery
Z-Wave Radio frequency (US):
908.42MHz (standard), 912.00MHz (default LR), 920.00MHz (backup LR)
Range:
More than 300 feet outdoor, about 130 feet indoors (depending on materials)
Operational Temperature:
32~104°F
Radio protocol:
Z-Wave Plus
Yes, the kit needs a Z-Wave hub. Don't have one yet? Add Ezlo Plus right above for $125 instead of $179.95
Already have a Z-Wave hub? The valve also works with Home Assistant and other Z-Wave compatible hubs
The motor mounts on a standard NPT ball valve in ¾″, 1″ or 1¼″. Pick the size of the pipe on your main water line
Not sure which one you have? Check the size marked on your current main shut-off valve or ask a plumber. We recommend professional valve sizing and installation
Putting the ball valve on your main water line is plumbing work, so we recommend a licensed plumber
The motor is detachable: it goes on the valve once the plumbing is done, so the electronics stay safe during the install. Then you pair it with your hub
Quick Start Guide
Installation Manual
Ezlo Water Valve Kit: Smart & Affordable Protection Against Water Damage
Take control of your home's safety with the Ezlo Water Valve Kit: the Ezlo Z-Wave Smart Water Shut-Off Valve with one, two or three Z-Wave flood sensors. Connect it to Ezlo Plus or another Z-Wave hub and manage it in the MiOS App, your first line of defense against leaks and water damage
View a live installation
Place the flood sensors where leaks usually start: under sinks, behind the washer, next to the water heater. The moment one detects water, your hub shuts off the valve and the MiOS App alerts you, so a small leak never becomes a flood
Latest Z-Wave Protocol Z-Wave 800 series for advanced, long-range connectivity up to 300ft outdoors
Instant Leak Alerts Real-time notifications through the MiOS App the moment water is detected
Compact, Flexible Placement Slim design fits under sinks, behind appliances and in other tight spots
Years of Battery Life Low-power design keeps every sensor on guard for years
Ezlo Smart Water Shut-Off Valve
Easy Setup, Detachable Design Separating the valve and actuator simplifies installation and protects the electronics from damage during the rough construction phase
Auto-Maintenance for Reliability Regularly cycles the valve automatically to prevent seizing and ensure it's always ready
MiOS App Dashboard Streamlined control for property managers and power users, locally and remotely
Manual Override Handle Manual override handle for control during power or network outages
Orchestrate your home with ease. With automation, you can shut off the lights from your car or control your thermostats from anywhere in the world. The only limitation is your own imagination.
Download on the App StoreGet it on Google Play
MiOS App on iPhone
Frequently Bought Together
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 179.95
Shop now ›
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now ›
Ezlo Smart Doorbell Camera
$ 179.97
Shop now ›
With over 10 years of experience, Ezlo has developed a platform trusted by dealers, builders, utilities, and real estate companies across the globe. Our technology processes 1.2+ billion smart events each month, powering over 1 million connected devices—all designed to work seamlessly together.
Trusted Around the World
Ezlo's solutions are used in 60+ countries and trusted by some of the biggest global brands. Our international team works every day to deliver reliable, scalable technology that transforms how people interact with their spaces.
What's New at Ezlo
New this season: Ezlo Sense health-aware sensing, Centralite Zigbee sensors, Frankever Wi-Fi switches and dimmers, and the Ezlo Water Valve Kits
