LEAK PREVENTION
Ezlo Smart Water Shut-Off Valve with Built-in Smart Hub
Regular price $272.93
Regular price $389.90 $272.93 Sale price
Documents
Ezlo Smart Water Shut-Off Valve – Hub Version
The Ezlo Smart Water Shut-Off Valve features a robust, two-part design with a separate high-quality brass ball valve and actuator—unlike some smart valves that rely on lower-grade components. This ensures superior water flow management, long-term reliability, and an IP67 rating, making it ideal for both indoor and outdoor use.
This version includes a built-in Z-Wave hub and connects seamlessly via the MiOS app. It acts as a central controller for your smart home system, allowing direct integration with other Z-Wave devices. Monitor your system, automate actions, and shut off your main water supply remotely in case of leaks or emergencies—all from a single, unified interface.
Built-In Z-Wave Hub –
Includes an integrated Z-Wave hub for direct smart home control, eliminating the need for a separate hub. Easily manage and connect compatible Z-Wave devices through the MiOS app for a seamless, all-in-one smart home experience.
With ¾”, 1”, and 1¼” valve sizes available, the Ezlo Smart Water Shut-off Valve easily fits your existing plumbing system.
    Lead-free brass ball Valves with commercial grade seals.
  • Polycarbonate enclosure, NEMA 4x (weather resistance)
  • Network:
    802.11 g/n/ac Dual Brand Wi-Fi 2.4 & 5GHz
  • Compatibility:
    Built-in Z-Wave hub feature
You can pair other Z-Wave devices with your water valve.
