Selling fastlimited stock at this price, order today
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
Remote Access Included
Yes* Usually a monthly plan
10 Years of Remote Access Included*
Your first EzloPi hardware purchase includes 10 years of Ezlo Cloud remote access for every EzloPi device included in that purchase — whether you buy a single device, a two-pack, or a larger multipack.
Remote access for additional EzloPi devices starts at $2.50 per month. Local control remains free on every device
Smart Wi-Fi Light SwitchFrankever · Model FK-SW101-US
Turn your lights on or off from anywhere. No hub required
Works with Alexa, Google Home and Home Assistant
$9.95
Bundle DealsIn Stock
1 pack
$9.95
SAVE $1.95
2 packs
$17.95
SAVE $4.90
3 packs
$24.95
Mix & match Any 2 for $17.95 · any 3 for $24.95
Smart Switch 2
Smart Dimmer 1
  • Effortless Device Control
  • App-enabled voice control
  • Connectivity with other smart devices via Home Assistant and Ezlo
  • Seamless Automation with MeshBots via MiOS app
Dimensions:
3.39 in x 3.39 in x 1.73 in (86 x 86 x 44 mm)
Power Supply:
AC 100-240V, 50/60Hz
Connectivity:
WiFi 2.4GHz (802.11 b/g/n)
Operating temperature:
14°F – 122°F (−10°C – 50°C)
Control:
On/off only; does not dim
Max Power Load:
800W per gang
Integrated Light:
2W (RGB + White)
App Support:
iOS and Android (MiOS, Home Assistant)
Wiring:
Line, load, neutral and ground required. No-neutral installation is not supported
FCCCERoHSWEEEWi-Fi Certified
Frankever Smart Switch wiring diagram
Specifications
High Voltage Device: Risk of Electric Shock — this device operates on AC 100-240V electricity. Installation requires direct interaction with your home's electrical wiring.
Turn Off Power: Always switch off the main power at your circuit breaker before attempting installation.
Professional Recommended: If you're not experienced with electrical wiring, we recommend hiring a licensed electrician to ensure a safe and code-compliant installation. If you are unfamiliar with electrical diagrams, line/load identification, or safety protocols, do not attempt to install this device yourself.
Looking for the full installation manual? A detailed step-by-step setup guide for the Frankever Smart Switch is available on Ezlo Support.
Open the Installation Manual
Upgrade to the Frankever Smart Switch for Local Control at the Wall or in the App
Control Your Lights at the Wall or in the App — even When the Internet Is Down. The Frankever Smart Switch puts EzloPi intelligence inside the switch for fast, private control that stays in your home
Instant response
Commands run on the switch itself, so your lights respond the moment you tap, swipe, or press
Private by default
Everyday control through the Ezlo app or Home Assistant stays on your home network. Only remote access uses Ezlo’s secure US-based cloud
Works through internet outages
If the internet is unavailable, the wall controls and the app on your home Wi-Fi keep working
Smart Control with a Built-In Nightlight
A built-in RGB nightlight behind the paddle adds a soft glow, making the switch easy to find in the dark. Turn the connected light on or off at the wall, through the MiOS app or Home Assistant, or with a compatible voice assistant. With Ezlo Cloud remote access, you can also control it when you’re away from home
Product
A soft glow for late nights
A soft glow behind the paddle guides you to the switch at night. Double-click to turn it on, double-click again to turn it off. No app, no extra lamp
True Local Operation
Maximum speed and privacy with zero cloud dependency
US-Based Cloud Operation
Secure remote access hosted entirely on compliant US-based servers when using MiOS. No overseas hops and no third-party relay between you and your home
Remote Control
Control your lights from anywhere, not just from your living room
Product
Automated Schedules
Custom timers and routines that execute locally, even without internet
Home Assistant Ready
Native integration available via HACS. Enjoy seamless BLE onboarding from your phone to configure your devices with absolutely no coding required
Built-In RGB Night Light
Customizable colors and brightness for functional and aesthetic ambiance
Effortless Home Assistant
Take full advantage of the native EzloPi Home Assistant Integration, available directly via HACS. We've made local control easier than ever:
Zero Coding Required
Build your perfect smart home ecosystem and configure devices without any programming knowledge
Local Control
All device control is handled locally, ensuring fast response times and privacy
BLE Onboarding
Easily onboard and configure devices using your iPhone or Android device
Smart lighting that adapts to your schedule Smart lighting that adapts to your schedule
Set a schedule once in the MiOS app and the switch follows it — lights on before dark, off when the house goes to sleep. Adjust it any time from your phone
Automations that span your whole home Automations that span your whole home
Build automations in the MiOS app that link the switch to the rest of your Ezlo system — motion in the hallway switches the lights on, and one tap turns everything off when you leave.
Easy to find in the dark Easy to find in the dark
Night Mode dims the switch's indicator LED after a set time, so you can find it in a dark hallway without a bright spot on the wall. Your lighting isn't affected
Frankever on the wall. EzloPi inside
The Open-Source, US-Secure Foundation for Your Smart Home
Choose ultimate control and peace of mind with EzloPi. Our Wi-Fi devices offer secure, local operation, a US-based cloud, and are built to be Home Assistant Ready, ensuring a future-proof, private, and reliable smart home experience
Before you buy
Will this switch work in my home?
Four quick questions about the switch you're replacing. They cover the reasons a smart switch doesn't fit.
Is there a neutral wire in the switch box?
Usually a bundle of white wires capped together at the back of the box, not connected to the old switch.
How many switches control this light?
Two switches for one light, like at the top and bottom of the stairs, is a 3-way circuit.
Does your Wi-Fi have a 2.4 GHz network?
Most home routers broadcast 2.4 GHz and 5 GHz at the same time.
Do you want to dim this light?
This switch turns the light on and off. It doesn't dim.
Answer the questions above to see if the Frankever Smart Switch fits.
Works with
What works, and where
"Works with" means different things in different apps. Here's what you can do in each one and what it needs.
AppSupportWhat you can doRuns locally?What you need
MiOS app✓ FullOn/off, schedules, MeshBot automations, nightlight and Night Mode, remote controlYes, on your home Wi-Fi. Away from home through Ezlo CloudiPhone or Android phone
Home Assistant✓ NativeOn/off and Home Assistant automationsYes, fully localEzloPi integration from HACS. Set up over Bluetooth from your phone
Amazon Alexa✓Voice on/offNo, through Ezlo CloudYour Ezlo account linked in the Alexa app
Google Home✓Voice on/offNo, through Ezlo CloudYour Ezlo account linked in the Google Home app
Apple Home / Siri✕ NoUse the MiOS app, or add the switch to Apple Home through Home Assistant's HomeKit Bridge
Matter✕ NoNot supported
Ezlo Plus hubOptionalAdds Z-Wave and Zigbee devices, including other brands, to the same MiOS appYesNot needed for this switch
When things go wrong
What still works without internet, Wi-Fi or power
The switch runs its own logic (EzloPi inside), so everyday control doesn't depend on the cloud.
If this happensWall switchApp at homeSchedulesAway from home and voice
Internet is down✓ Works✓ Works✓ Keep runningPaused until the internet is back
Ezlo Cloud unavailable✓ Works✓ Works✓ Keep runningPaused. Home Assistant keeps working
Wi-Fi router is off✓ Works✕ The app can't reach the switch✓ Keep running✕
Power cutWhen the power comes back, the switch starts with the light off and rejoins your Wi-Fi on its own.
Which one do you need?
Smart Switch or Smart Dimmer?
Both work in the same MiOS app, need the same wiring, and can be mixed and matched in the bundle above.
Smart SwitchYou're hereSmart Dimmer
ModelFK‑SW101‑USFK‑SW102‑US
Best forPorch, hallway, closet, garageLiving room, bedroom, dining room
BrightnessOn/off onlyDims from 0 to 100% at the wall or in the app
Max load800 W per gang400 W incandescent, 150 W dimmable LED, 150 W CFL
Neutral wireRequiredRequired
Price$9.95$9.95
View the Smart Dimmer →
Specifications
The full technical sheet
ModelFK-SW101-US
Switch typeSingle-pole, on/off only. Does not dim
WiringLine, load, neutral and ground required. No-neutral installation is not supported
Power supplyAC 100–240 V, 50/60 Hz
Max power load800 W per gang
ConnectivityWi-Fi 2.4 GHz (802.11 b/g/n). Set up over Bluetooth from your phone
HubNot required
NightlightBuilt-in RGB + white, 2 W. Double-click the switch to turn it on or off
Dimensions3.39 × 3.39 × 1.73 in (86 × 86 × 44 mm)
Operating temperature14°F – 122°F (−10°C – 50°C)
AppsMiOS (iOS and Android), Home Assistant (EzloPi integration via HACS)
VoiceAmazon Alexa, Google Home
Remote accessEzlo Cloud, hosted in the US
After a power cutStarts with the light off and reconnects to Wi-Fi automatically
Firmware updatesOver the air through the MiOS app
Wiring diagram, safety warning and the installation manual are in the technical specifications at the top of this page.
Frequently Asked Questions
Q: Are these compatible with Home Assistant?
A: Yes. The Frankever Wi-Fi devices are "Home Assistant Ready" through the native EzloPi integration available via HACS. Built on the open-source EzloPi platform, they integrate seamlessly for users who want advanced, local control over their smart home ecosystem. Setup is a breeze with simple BLE onboarding from your iOS or Android device—no programming knowledge required
Q: Do I need a hub to use these switches?
A: No. The Frankever In-Wall Switches and Dimmers are Wi-Fi enabled (2.4GHz). They connect directly to your home network without needing a separate hub or gateway
Q: Do I need a neutral wire?
A: Yes. Both the Frankever Smart Switch and Smart Dimmer require a neutral wire in the switch box. If your box has only line and load wires, which is common in homes built before the 1980s, these switches will not work there. Check the wiring before you buy, or ask an electrician to add a neutral
Q: Will it work on a 3-way circuit, or dim my lights?
A: No. The Frankever Smart Switch replaces a single switch that controls a light on its own, and it turns the light on and off without dimming. For dimming, choose the Frankever Smart Dimmer: same price, same app
Q: Will my switches still work if my internet goes down?
A: Yes. These devices utilize a "Local-First" architecture. This means your automated schedules, timers, and manual controls are processed locally on the device. Even during an internet outage, your lighting control remains fully functional
Q: What happens after a power cut?
A: When the power comes back, the switch starts with the light off and reconnects to your Wi-Fi on its own
Q: How is my data and privacy protected?
A: We prioritize data sovereignty. While many smart devices route data through overseas servers, Frankever devices utilize a US-Based Cloud for backups. Your data remains secure and is hosted entirely on compliant servers within the United States
Q: What does the cloud cost?
A: Ezlo Cloud is included free for 10 years on your first EzloPi device with your first hardware purchase. Adding more EzloPi devices starts at $2.50 a month
Q: Does the switch get firmware updates?
A: Yes. Setup in the MiOS app installs the latest firmware, and later updates install over the air through the app. You never need to take the switch out of the wall
Q: Is the MiOS app just for this switch?
A: No. MiOS is Ezlo's app for your whole home. It runs Frankever switches and dimmers, other EzloPi Wi-Fi devices, and Ezlo hubs such as Ezlo Plus, which add Z-Wave and Zigbee devices from many brands. One account and one app for all of them
Q: What if I'm not comfortable doing the wiring myself?
A: Safety is our top priority. The installation involves handling high-voltage wiring (AC 100-240V). If you are unsure about identifying line/load wires or safely installing the device, we strongly recommend hiring a licensed professional electrician to perform the installation
Q: Who can I contact for technical support or other inquiries?
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com
One app for your whole home
The MiOS app runs this switch alongside the rest of your home: Frankever switches and dimmers, EzloPi Wi-Fi devices, and Ezlo hubs that bring in Z-Wave and Zigbee devices from many brands. Schedules, automations and remote control for all of them, in one place
Download on App Store App Store QR
Get it on Google Play Google Play QR
Add another when you need it
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 125.97
Shop now ›
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now ›
Ezlo Smart Doorbell Camera
$ 179.97
Shop now ›
Trusted Around the World
What's New at Ezlo
