191 Hubs already found their owners
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
No Subscriptions
Yes No
Ezlo Plus Smart
Home HubModel EzloPlus-US
One hub for your whole smart home
Z-Wave, Zigbee & Wi-Fi — no monthly fees
$179.95
  • Z-Wave & Zigbee Compatible — thousands of devices
  • No Monthly Fees — powerful self-monitored security at no extra cost
  • Works With Alexa, Google & Siri
  • Advanced Automation with MeshBots
Dimensions:
4.17 x 4.12 x 1.45 in
(106 x 104.66 x 36.95 mm)
Power Supply:
Input: AC 100-240VAC, 50-60Hz
Output: DC 5V/2A
CPU:
Quad-Core Cortex-A7 ARM CPU
RAM Memory:
DDR3 512MB
Flash memory:
Parallel NAND Flash EMMC 4GB
Z-Wave Module:
Zigbee Module:
Zigbee 3.0 Internal Antenna
Network:
Ethernet, Wi-Fi, and 4G/LTE Cellular
LAN Port: 10/100 Ethernet port with RJ45 connector
Support Standards: 802.11g/n/ac Dual Band WiFi 2.4 & 5GHz
FCCCERoHSWEEEULZ-Wave PlusWi-Fi CertifiedZigbee
Quick troubleshooting section
  • Control Wi-Fi, Z-Wave & Zigbee devices, including lights, locks, thermostats, door locks, sensors & more
  • Create Mesh Bot scenes, including triggers and actions
  • Local control for ultra-fast responsiveness
  • Remote access via iOS, Android and the MiOS portal
Smart. Secure. Easy
Transform your living space into a modern smart home with the Ezlo Plus Smart Home Z-Wave & Zigbee Hub
Modernize your living space with the versatile Ezlo Plus Z-Wave & Zigbee Smart Home Hub
This powerful hub acts as a universal solution, allowing you to unify and manage all your smart devices within a single, seamless ecosystem.
Supporting both Z-Wave and Zigbee protocols
it offers maximum flexibility for your setup. Whether you are controlling lights and locks or managing sensors and switches, the Ezlo Plus covers every use case with ease.
Effortlessly manage your home through the intuitive MiOS app
This streamlined interface makes your smart home more efficient and user-friendly, ensuring your setup is both convenient today and future-proof for tomorrow.
Powered by the advanced Z-Wave 700 series chip
The hub delivers faster communication, wider range, and superior energy efficiency. With integrated S2 Security, it guarantees encrypted and secure connections for total peace of mind.
Quietly Powerful. Always On
The Ezlo Plus sits in the background so your smart home can take center stage. Managing thousands of Z-Wave and Zigbee devices from a single hub.
Z-Wave & Zigbee Control
Thousands of compatible devices, one seamless ecosystem.
MiOS App Dashboard
Streamlined control for property managers and power users, locally and remotely
Voice Assistant Ready
Works with Amazon Alexa, Siri Shortcuts, and Google Assistant for hands-free control
MeshBot Automation
Smart routines that run locally first — faster performance, less cloud dependency
Your Security System.
The Ezlo Plus turns your smart home into a powerful, self-monitored safety system — delivering real-time alerts and automation through MiOS.
Real-Time AlertsReal-Time Alerts
Get instant notifications the moment something happens — motion, door, water, smoke — wherever you are
Local ProcessingEverything runs on-device first, so your security stays active even when your internet goes down
MiOS AutomationSet custom rules that respond automatically — lights on when motion is detected, locks engaged when you leave, alerts sent the moment something's off
Ezlo Plus Smart Home Hub
Connectivity with Multiple Radio Frequencies and Devices Connectivity with Multiple Radio Frequencies and Devices
The Ezlo Plus hub provides comprehensive control over thousands of Z-Wave and Zigbee devices, functioning as a subscription-free, self-monitored safety system with powerful MiOS automation.
Voice Control Voice Control
Voice Control
Use your favorite voice assistants like Amazon Alexa, Siri Shortcuts, and Google Assistant to easily manage your smart home and experience the convenience of hands-free control.
Effortless Device Control Effortless Device Control
The redesigned MiOS App offers a streamlined dashboard for power users and property managers, combining swift local control and secure remote access with enhanced device filtering.
Powered by MiOS — The Smart Home OS
One platform to connect, control, and automate your entire home
MiOS is the operating system running behind every Ezlo Plus — turning a powerful hub into a truly intelligent home. From the intuitive app dashboard you can manage every device in every room, build complex automations with MeshBots, and connect to the cloud services you already use. Whether you're setting a bedtime routine or monitoring your home from across the world, MiOS handles it seamlessly — locally first, always private, always on
Frequently Asked Questions
Q: What devices are compatible with the Ezlo Plus smart home hub?
A: The Ezlo Plus offers extensive compatibility with thousands of new and legacy Z-Wave and Zigbee devices, including lights, thermostats, locks, and sensors (such as the Centralite lineup), giving you maximum flexibility to expand your ecosystem.
Q: How does the MiOS App manage my smart home devices?
A: The app provides two management methods: Local Management for swift, direct control within your home, and Cloud-Based Management for secure access to your devices from anywhere in the world at any time.
Q: What makes the redesigned MiOS Dashboard beneficial for power users?
A: The new dashboard features a streamlined interface with enhanced filtering and quick access to key devices, making it an ideal tool for both power users and property managers who need to handle complex setups efficiently.
Q: What are MeshBots and how do they enhance automation?
A: MeshBots are advanced automation commands that orchestrate interactions between cloud services, local devices, and apps. They prioritize local execution whenever possible to ensure faster performance and reduced reliance on the internet.
Q: Who can I contact for technical support or other inquiries?
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com.
Orchestrate your home with ease. With automation, you can shut off the lights from your car or control your thermostats from anywhere in the world. The only limitation is your own imagination.
Download on App Store App Store QR
Get it on Google Play Google Play QR
Frequently Bought Together
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now ›
Ezlo Smart Doorbell Camera
$ 179.97
Shop now ›
With over 10 years of experience, Ezlo has developed a platform trusted by dealers, builders, utilities, and real estate companies across the globe. Our technology processes 1.2+ billion smart events each month, powering over 1 million connected devices—all designed to work seamlessly together.
Trusted Around the World
Ezlo's solutions are used in 60+ countries and trusted by some of the biggest global brands. Our international team works every day to deliver reliable, scalable technology that transforms how people interact with their spaces.
What's New at Ezlo
New this season: Ezlo Sense health-aware sensing, Centralite Zigbee sensors, Frankever Wi-Fi switches and dimmers, and the Ezlo Water Valve Kits
