The built-in Z-Wave hub pairs the leak sensors straight to the valve over a reliable, low-power mesh
Connects to your 2.4 or 5 GHz Wi-Fi with a hub built in, no separate hub needed
About this item
- • Advanced Leak Detectionwith Latest Z-Wave 800 series
- • Equipped with a temperature sensorto detect leaks, burst pipes, and overflows—alerts you before major damage occurs
- • Receive instant notifications on your phone,even when away from home
Ezlo Wi-Fi Smart Water Shut-Off Valve Kit (No Hub Needed)
Ezlo WiFi + Z-Wave Smart Water Shut-Off Valve with Built-in Smart Hub
Ezlo Z-Wave Flood Sensor
Extension probe: 50 mm(W)*5mm(H),
Wire: 1000mm(L)
No. This valve has a hub built in: it joins your Wi-Fi and pairs the Z-Wave leak sensors directly
The motor mounts on a standard NPT ball valve in ¾″, 1″ or 1¼″. Pick the size of the pipe on your main water line
Not sure which one you have? Check the size marked on your current main shut-off valve or ask a plumber. We recommend professional valve sizing and installation
Putting the ball valve on your main water line is plumbing work, so we recommend a licensed plumber
The motor is detachable: it goes on the valve once the plumbing is done, so the electronics stay safe during the install. Then you connect it to your Wi-Fi in the MiOS App
Quick Start GuideEzlo Z-Wave Flood Sensor
Installation ManualEzlo Wi-Fi Water Valve Kit: Smart & Affordable Protection Against Water Damage
Take control of your home's safety with the Ezlo Wi-Fi Water Valve Kit: the Ezlo WiFi + Z-Wave Smart Water Shut-Off Valve with a built-in hub and one, two or three Z-Wave flood sensors. It connects straight to your Wi-Fi, no separate hub needed, and you manage it in the MiOS App, your first line of defense against leaks and water damage
View a live installationPlace the flood sensors where leaks usually start: under sinks, behind the washer, next to the water heater. The moment one detects water, the valve shuts off the water and the MiOS App alerts you, so a small leak never becomes a flood
Orchestrate your home with ease. With automation, you can shut off the lights from your car or control your thermostats from anywhere in the world. The only limitation is your own imagination.
Frequently Bought Together
With over 10 years of experience, Ezlo has developed a platform trusted by dealers, builders, utilities, and real estate companies across the globe. Our technology processes 1.2+ billion smart events each month, powering over 1 million connected devices—all designed to work seamlessly together.
Trusted Around the World
Ezlo's solutions are used in 60+ countries and trusted by some of the biggest global brands. Our international team works every day to deliver reliable, scalable technology that transforms how people interact with their spaces.
What's New at Ezlo
New this season: Ezlo Sense health-aware sensing, Centralite Zigbee sensors, Frankever Wi-Fi switches and dimmers, and the Ezlo Water Valve Kits
