82 Sensors already found their owners
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
No Subscriptions
Yes No
Ezlo Z-Wave Flood SensorModel EZL-ZW-FLD-US
Prevent $10,000+ water damage
before it happens
$28.95
Bundle DealsIn Stock
1 pack
$28.95
SAVE $2.90
2 packs
$55
SAVE $8.68
3 packs
$78.17
  • 2-in-1 Detection — water and temperature monitoring
  • Z-Wave 800 Series — superior range up to 300ft outdoors
  • Automated Response — triggers smart valves and alerts instantly
  • Works with Home Assistant, MiOS & major Z-Wave hubs, Ezlo and Ezlo protect
Dimensions:
Main body: 68 mm(W)*22mm(H),
Extension probe: 50 mm(W)*5mm(H),
Wire: 1000mm(L)
Power Supply:
ER14250 3.6V Battery
Z-Wave Radio frequency (US):
908.42MHz (standard), 912.00MHz (default LR), 920.00MHz (backup LR)
Radio protocol:
Z-Wave Plus
Range:
More than 300 feet outdoor, about 130 feet indoors (depending on materials)
Operational Temperature:
32~104°F
FCCCERoHSZ-Wave PlusWi-Fi CertifiedZigbeeULWEEE
Specifications
Power Source: This device requires a single ER14250 3.6V Battery. Thanks to ultra-low power consumption, it is designed for long-lasting operation.
Probe Placement: The sensor includes a 1000mm (3.2 ft) wire probe. Place the probe tip where water is most likely to accumulate (e.g., under a sink) or at the desired water line (for tanks/pools).
Looking for the full installation manual? A detailed step-by-step setup guide for the Ezlo Z-Wave Flood Sensor is available in our Support Center.
Open the Installation Manual
Detects leaks before they become expensive disasters
Complete protection for your smart home or office: prevent water damage before it happens with the Ezlo Z-Wave Flood Sensor. From burst pipes to low pool levels, get instant alerts on leaks and floods.
Superior Range
Built on the latest Z-Wave 800 series for faster, more reliable connectivity throughout your home
2-in-1 Monitoring
Equipped with temperature sensor to detect freezing pipes
Always On
Ultra-low power consumption ensures continuous, long-term protection on a single ER14250 battery
Versatile Use
Perfect for detecting burst pipes, leaking overflow units, or diminishing water levels in pools and tanks
Stop Leaks Proactively with Ezlo Water Valves
Maximize your peace of mind by linking your sensor to the Ezlo Water Valve. Seamless integration allows the sensor to automatically trigger the valve to close, stopping disasters in their tracks even when you aren't home.
Latest Z-Wave Protocol
Utilizes the Z-Wave 800 series for advanced, long-range connectivity
US-Based Customer Care: Enjoy peace of mind with US-based, real-person customer support ready to assist you whenever you need help.
Real-person support available whenever you need help — no bots, no overseas queues
Advanced Automation: Seamlessly integrate with MiOS and EzloPi for complex automation routines.
Ultra-Low Power
Long-lasting battery life with a low battery alert so you're never caught off guard
Voice Activation:
Compatible with Amazon Alexa and Google Assistant, allowing for hands-free control of associated devices
Works With Your Smart Home
The Ezlo Z-Wave Leak Sensor is built on the Z-Wave 800 series protocol, making it natively compatible with Home Assistant and virtually any Z-Wave hub — no lock-in, no proprietary ecosystem required
Home Assistant Native
Integrates seamlessly via Z-Wave Plus S2 Security. Full local control, instant alerts, no cloud dependency required
Open Z-Wave Ecosystem
Works with any Z-Wave compatible hub — Ezlo, Hubitat, SmartThings, and more. Your sensor, your platform
Automated Response
Link directly to a smart water valve or siren via Z-Wave BASIC SET commands — stopping leaks automatically, even without hub intervention
Superior Battery Longevity Superior Battery Longevity
Ultra-low power Z-Wave technology ensures years of reliable, uninterrupted performance.
Flexible Water Detection Flexible Water Detection
The sensor can be used with its built-in prongs for direct floor placement or utilize the extension probe to reach remote or difficult-to-access areas, ensuring comprehensive coverage.
Stop Disasters Automatically with Ezlo Water Valves Stop Disasters Automatically with Ezlo Water Valves
Upgrade your home’s defense by pairing your sensors with the Ezlo Water Valve. Through seamless integration, a detected leak automatically triggers the valve to shut off—stopping floods in their tracks even when you’re miles away. Enjoy total peace of mind with proactive, hands-free protection.
Powered by the MiOS automation platform
The Open Engine Behind Every Ezlo Device
Connect the Flood Sensor to MiOS and build powerful MeshBot automations — automatically shut a water valve, sound a siren, or send an instant alert the moment a leak is detected. Open, local, and endlessly extensible
Frequently Asked Questions
Q: Do I need a hub to use this sensor?
A: Yes. This is a Z-Wave 800 Series device. It requires a Z-Wave compatible hub (such as an Ezlo controller or other Z-Wave gateways) to send alerts to your phone and trigger automations.
Q: What exactly does it detect?
A: It features Dual Detection Capability. It can detect sudden water presence (leaks and floods) to prevent damage, but it can also detect critically low water levels, making it perfect for monitoring pools or water tanks.
Q: Does it monitor anything besides water?
A: Yes. It provides Integrated Monitoring with a Temperature Sensor, to detect freezing conditions before pipes burst
Q: How far is the wireless range?
A: It utilizes the latest Z-Wave 800 Series protocol. This provides long-range connectivity, capable of reaching more than 300 ft outdoors and approximately 130 ft indoors, ensuring reliable alerts even from basements or garages.
Q: Can it trigger other devices automatically?
A: Yes. You can set up Automated Schedules and scenes. For example, if a leak is detected, the sensor can automatically trigger a smart water valve to shut off the main water line or sound a siren to alert you immediately.
Q: Does it work with Home Assistant?
A: Yes. The sensor is "Home Assistant Ready." It integrates seamlessly for users who want to create complex automation rules within the Home Assistant ecosystem.
A: If you need help with placement or pairing, we are here to assist. Please contact our customer care team at 866-966-2272 or email us at support@ezlo.com.
Orchestrate your home with ease. With automation, you can shut off the lights from your car or control your thermostats from anywhere in the world. The only limitation is your own imagination.
Download on App Store App Store QR
Get it on Google Play Google Play QR
Frequently Bought Together
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 179.95
Shop now ›
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now ›
Ezlo Smart Doorbell Camera
$ 179.97
Shop now ›
With over 10 years of experience, Ezlo has developed a platform trusted by dealers, builders, utilities, and real estate companies across the globe. Our technology processes 1.2+ billion smart events each month, powering over 1 million connected devices—all designed to work seamlessly together.
Trusted Around the World
Ezlo's solutions are used in 60+ countries and trusted by some of the biggest global brands. Our international team works every day to deliver reliable, scalable technology that transforms how people interact with their spaces.
What's New at Ezlo
New this season: Ezlo Sense health-aware sensing, Centralite Zigbee sensors, Frankever Wi-Fi switches and dimmers, and the Ezlo Water Valve Kits
