Smart Zigbee3.0 24Ghz Human Presence Sensor for Home Assistant Platform Zigbee2Mqtt 120 Degree Detection Range 30M
Lincukoo Smart Zigbee3.0 24GHz Human Presence Sensor for Home Assistant Platform Zigbee2MQTT 120 Degree Detection Range 30m
Important Note:
The HZ version only be used on Home Assistant platform, need to use
- This sensor can not only detect human motion but also detect human presence, it means it can not only detect the moving moment, but also can monitor the status of human stay in the range
-Both the detect distance(3-6meters), the sensitivity (10 levels) and the hold on time(the delay after a person leaves the detect range) are adjustable, so that meet needs of different scenario
-Suitable for rooms that require the light/air-conditioner/curtain etc to be turned on when someone is present for long time and turned off when there is no one there, such as meeting room, reading room, living room…
-Support linkage with other devices through gateway, for example, if there is someone is detected in range, turn on the light and keep, until there is no one in the range, then turn off the light.
Product information:
Version:HZ
Platform support:Home Assistant Tuya,Home Assistan
Transmission Protocol:Zigbee3.0
Zigbee to MQTT support :Yes
Transmission distance(max):30meters 40meter
Detect range:3-6meters adjustable
Sensitivity adjustable:Yes
Power in:5v type-c
IP grade:IP64
Install mothed:Double-sided tape
Certification:CE,Rohs,FCC
