33 Sensors already found their owners
See the difference
Ezlo Other Brands
Local Automation
Yes No
Works Offline
Yes No
Multi-Device Automations
Yes Limited
No Subscriptions
Yes No
Motion SensorCentralite · Model CLZ-3370-C
Stop a $5,000+ burglary
before it happens
$15.95
Bundle DealsIn Stock
1 pack
$15.95
SAVE $7.90
3 packs
$39.95
SAVE $16.80
5 packs
$62.95
  • Effortless Device Control
  • Voice Control via an application
  • Connectivity with Multiple Radio Frequencies and Devices
  • Seamless Automation with MeshBots via MiOS
Model Number
CLZ-3370-C
Battery Specifications
3.7V 500 mAh Micro-USB Charging Port
Operating temperature
14°F – 120°F
Operating humidity
10% – 90% RH (no condensation)
Detection distance
19 – 26 feet
Detection sensor
PIR Infrared
Wireless Connectivity
ZigBee 3.0
FCCCERoHSZigbeeULWEEE
Centralite Motion Sensor — device overview
Built-In Rechargeable Battery: Charge only with a standard 5V Micro-USB charger. Do not puncture, disassemble, or expose the device to fire or extreme heat
Indoor Use Only: Designed for indoor environments within 14°F – 120°F and non-condensing humidity. Keep away from water and direct sunlight
Looking for the full installation manual? A detailed step-by-step setup guide for the Centralite Motion Sensor (CLZ-3370-C) is available in our Support Center.
Open the Installation Manual
Centralite Zigbee 3.0
Rechargeable Motion Sensor
Enhances home security through advanced infrared detection, offering real-time alerts via the MiOS app and seamless integration with Home Assistant for powerful smart home automation
Advanced Motion Detection
The Centralite CLZ-3370-C uses infrared technology and reliable Zigbee 3.0 to track human and animal movement, effortlessly enhancing your home security
Smart Home Automation
Compatible with major hubs, this sensor turns motion into action. Easily connect it with other smart devices to trigger custom scenarios like turning on lights
Real-Time MiOS App Alerts
Monitor your home from anywhere via the MiOS app for iOS and Android. Its user-friendly interface sends instant, real-time alerts straight to your smartphone
Home Assistant Ready
For ultimate flexibility, the sensor fully integrates with Home Assistant. This enables deep-dive, complex automations and complete control over your smart ecosystem
Centralite Motion Sensor in a modern home
The Centralite Motion Sensor
The Centralite Motion Sensor CLZ-3370-C uses infrared sensors to detect movement and works in conjunction with smart home hubs which enables smart home automation and app alerts
Motion Detection
Uses infrared sensors to detect movement of people or animals
Enables automation and app alerts for enhanced security
Easy Pairing
Pairs with the MiOS mobile app and other Zigbee hubs
Zigbee 3.0 Connectivity
Integrates seamlessly with Zigbee-compatible smart home hubs
Includes a 3.7V 500 mAh Micro-USB charging port
Flexible Placement
Compact design with adhesive mounting for easy installation
Works With Your Smart Home
The Centralite CLZ-3370-C is a Zigbee 3.0 certified sensor — it plugs straight into the smart home you already have
Home Assistant ReadyIntegrates via any Zigbee coordinator for advanced local automations and complete control
Zigbee 3.0 CertifiedPairs with Ezlo hubs and hundreds of certified Zigbee controllers and devices
MiOS App ControlPair, configure, and get instant motion alerts from your iPhone or Android in minutes
Automated Hallway Lighting Automated Hallway Lighting
Say goodbye to fumbling in the dark. Place the Centralite Motion Sensor in your hallway and sync it with smart switches or bulbs via the Ezlo app. Set up custom scenes to gently guide your steps with soft, automatic light. Whether you're sneaking to the kitchen for a midnight snack or moving between rooms, enjoy effortless, sleep-friendly navigation without waking the house
Advanced automation with scripting Advanced automation with scripting
Let your home welcome you the moment you step through the door. By placing the Centralite Motion Sensor near your front or back entrance, you can trigger instant, automated actions. Group it with smart switches or bulbs in the Ezlo app to activate custom scenes. Whether you are arriving late at night or keeping an eye on after-hours activity, auto-lighting and instant alerts make managing your home's entry points effortless
Protecting Your Home Protecting Your Home
Centralite Motion Sensor is the ultimate guardian of your home, watching over you and your family 24/7
Frequently Asked Questions
Q: Do I need a hub to use this sensor?
A: Yes. The CLZ-3370-C is a Zigbee 3.0 device, so it needs a Zigbee-compatible hub. It pairs seamlessly with Ezlo hubs (like Ezlo Plus) and other major Zigbee controllers
Q: Is it compatible with Home Assistant?
A: Yes. As a standard Zigbee 3.0 sensor it works with Home Assistant through any supported Zigbee coordinator, enabling advanced local automations and full control of your smart home ecosystem
Q: How do I charge the sensor?
A: The sensor has a built-in 3.7V 500 mAh rechargeable battery with a standard Micro-USB charging port — no battery replacements needed. Just plug it into any 5V USB charger
Q: Where should I place the sensor?
A: Anywhere indoors. The compact design mounts on any flat surface with the included adhesive — hallways, entryways, and corners work best. Detection reaches 19–26 feet with a 110° angle
Q: Will my automations work if the internet goes down?
A: Yes. With an Ezlo hub your motion-triggered automations run locally, so scenes like turning on lights keep working even during an internet outage. Only remote notifications require connectivity
Q: How is my data and privacy protected?
A: We prioritize data sovereignty. Ezlo devices utilize a US-Based Cloud — your data remains secure and is hosted entirely on compliant servers within the United States
A: We are here to help! For any additional questions or technical assistance, please contact our customer care team at 866-966-2272 or email us at support@ezlo.com
Download on App Store App Store QR
Get it on Google Play Google Play QR
Frequently Bought Together
Ezlo Plus Smart
Home Hub
Ezlo Plus Smart
Home Hub
$ 179.95
Shop now ›
Ezlo Smart Z-Wave LED Bulb
$ 10.00
Shop now ›
Ezlo Smart Doorbell Camera
$ 179.97
Shop now ›
Trusted Around the World
What's New at Ezlo
New this season: Ezlo Sense health-aware sensing, Centralite Zigbee sensors, Frankever Wi-Fi switches and dimmers, and the Ezlo Water Valve Kits
