Smart Vibration Sensor Zigbee Sensor Monitor App Control Security Protection Zigbee Sensor Motion Shock Alarm Support Z2M
2025/6/10 update: Current version: It does not work with tuya App/zigbee hub, only with Home Assistant zigbee2mqtt! Pictures App screenshots is tuya, can not reference! If you need the version work with tuya, please wait for update, thank you!
This Zigbee Vibration Sensor must work with Zigbee gateway(Hub). It cannot connect to WiFi router directly.
Specification
Working voltage: DC 3V
Wireless connections: ZigBee 3.0(need to use zigbee hub)
Standby current: ≤10uA
Alarm current:≤20mA
Standby time: ≥15 months
Transmission distance:10-30 meters(no obstruction indoor)
Battery:
1.5V AAA dry battery*2 (not included)
Working temperature: -10°C~50℃
Working humidity: ≤95%
Package Content
1* Zigbee Smart Vibration Sensor
1* User Manual
1* Reset Pin
1* Double-sided Sticker
【Vibration Detection Sensor】Enable the vibration detection function in the Smart App. When the device detects vibration, the APP alarm notification function will be triggered. Really monitor your home safety.
【Sensitivity Setting】You can set the sensitivity in the App according to your needs, with a wide range from low to high; support historical records to monitor your home more accurately.
【Real-time Remote Monitoring】No matter when and where, once the vibration sensor detects vibration or movement, you will receive a push notification from your smartphone in the Smart App as real-time monitoring.
【Smart Linkage】The vibration sensor can be used in conjunction with other smart products to achieve smart linkage for the whole house (smart scenes need to be created)
