Smart Life Zigbee Human Presence Sensor 24G Mmwave Radar PIR Motion Temp Humidity Brightness for Tuya 2MQTT Security Automation
📌 Important Note: Zigbee Hub Required
This sensor operates on the Zigbee 3.0 protocol and requires a compatible Zigbee hub (gateway) to connect to your network and enable app control and smart automations. The hub is not included and must be purchased separately. Please ensure you have or purchase a compatible Zigbee hub before ordering.
🛒 8 Models Available – Choose According to Your Needs
We offer 8 different models, all requiring a Zigbee hub. Please review the differences carefully to select the right version for your setup:
TYPE 1: Motion detection only. Does NOT support Tuya/Smart Life apps, Zigbee Hub Reuqired
TYPE 2: Motion detection only. Supports Tuya/Smart Life apps,Zigbee tuya hub required.
TYPE 3: Motion + Static Presence detection. Supports Zigbee2MQTT. Does NOT support Tuya/Smart Life apps, Zigbee hub required.
Model 4: Motion + Static Presence detection. Supports Tuya/Smart Life apps, Zigbee tuya hub required
Model 5: Motion + Static Presence detection. Includes bracket. Supports Zigbee2MQTT,Zigbee Hub Required.
Model 6: Motion + Static Presence detection. Includes bracket. Supports Tuya/Smart Life apps, Zigbee Tuya Required.
Model 7(LUX TH): Motion + Static Presence detection. Includes bracket. Supports Zigbee2MQTT,Zigbee Hub Required, With light/temperature/humidity detection .
Model 8(LUX TH): Motion + Static Presence detection. Includes bracket. Supports Tuya/Smart Life apps, Zigbee Tuya Required, With Light/Temperature/Humidity Detection
✨ Key Features- for certain verison✨
🔍 Precise mmWave Radar Detection
Utilizes a 24GHz high-precision radar module to detect human presence within a range of up to 5 meters and a 120° wide angle. It continuously identifies people even when they are still, sitting, or sleeping—eliminating the blind spots of traditional "motion-only" sensors.
📦 Ultra-Compact & Discreet Design
Measures only 33mm x 33mm x 16mm (26mm thick for some models). Install easily using the included 3M adhesive tape or an optional magnetic stand (sold separately). Fits seamlessly in corners, on ceilings, inside cabinets, and more.
✨New Update -For certain version:
🌡️ Temperature Detection
💡 Light Detection
💧 Humidity Detection
These three features are not included in all models. Please check your version before use.
📱 Smart Connectivity & Automation-for certain verison
Connects via Zigbee 3.0 to work with platforms like Tuya Smart / Smart Life for real-time app alerts, history logs, and automations. Create scenes like lights on when someone enters, lights off when empty; trigger recordings or security alerts; and more.
⚙️ Adjustable Parameters for Custom Sensing
Fine-tune the radar detection distance, motion sensitivity, and stationary sensitivity directly from the app to match different area requirements (e.g., bathroom, hallway, office).
🏠 Versatile Applications
Ideal for multiple environments: living rooms, bedrooms, bathrooms, hallways, offices, storage rooms, and shops. Enable smart lighting, security alerts, energy savings, and more for a convenient and secure lifestyle.
🎯 Buying Guide
If you already own a Zigbee hub, select the model based on your desired detection type (motion-only or motion+presence) and preferred platform (Tuya ecosystem or Zigbee2MQTT).
If you do not have a hub, please purchase a compatible Zigbee gateway separately to set up your smart sensing network.
Start Building a Smarter Space with Reliable Sensing. The Gleco Human Presence Sensor – Your Invisible, Intelligent Guardian.
Package included:
1*sensor(included battery)
1*manual
