Ewelink Zigbee Smart Human Body Infrared Sensor PIR Motion Detect Sensor Smart Home Security Alarm Work with Alexa Google Home
eWeLink Zigbee PIR Motion Detection Sensor Smart Home Zigbee Human Infrared Sensor Security Alarm Work with Alexa Google Home
Description:
1. The product is small, not easy to be found, does not affect the appearance.
2. Simple to use, with double-sided tape, no need to install wiring, can be arbitrarily attached.
3. Emergency alert push function, when the intentional motion is detected, the wireless motion sensor will push the alarm to your mobile phone application.
4. Sensitive response, strong anti-interference, intelligent APP control, 360° all-round detection without dead corners
5. Wide range of use, such as rooms, garages, safes, corridors, doorways, shops, cafes, etc
Product Parameter:
Note:It can not be used alone and needs to be paired with the eWeLink ZigBee3.0 gateway.
Wireless Protocol: ZigBee3.0
APP Operation Platform: eWeLink APP ,work with Alexa Google Home...
USB Input: DC5V/2A (Using USB can not use dry battery)
Input voltage: DC3V LR03*2 ( Not Included Battery )
Static Current: ≤45uA
Alarm Current: ≤15mA
Low Voltage: ≤2.5V
Zigbee Frequency: 2.400GHZ-2.484GHZ
Detection Distance: 6M
Detection Angle: 360° Ceiling Mounted
Installation Method: Ceiling/Wall hanging
Operating temperature: -10-50℃
Operating humidity: Max. 95%RH
The best mounting height for wall mounting is 1.2-1.5m (note that it needs to be used with a gateway, this sensor is suitable for easy micro-connection systems)
Package Included:
1 x eWeLink Zigbee PIR Motion Sensor
