Zigbee3.0 Tiny Water Leakage Smart Sensor Smart Leakage Detector Alarm Supports Zigbee2Mqtt Home Assistant Ewelink
$17.85
Lincukoo ZigBee3.0 Tiny Water Leakage Smart Sensor Smart Leakage Detector Alarm Supports Zigbee2MQTT Home Assistant eWeLink
Important Note:
The HZ version only be used on Home Assistant or Ewelink platform, need zigbee gateway to use
a).Go to the link to buy
Tiny Smart Water Leakage Sensor Description:
-Detect water leakage real time: Through gateway, it can send notification to user's mobile phone when water leakage detected, and also linkage with other devices to build up smart application scene, for instance, close the water valve in case of kitchen sink leaks
-Tiny size(37*37*8mm): Can be place into narrow gaps, such as under washing machines, beneath sinks, in pipe gaps, and other narrow and hard-to-notice areas prone to leaks, ensuring prompt action to safeguard your home.
-IP66 Waterproof and Durable: Designed with IP66 waterproofing, providing reliable operation even in highly humid environments such as bathroom, kitchen for long time.
-Tool-free Installation
You don't need any complicated wiring or tools. Just put it to the place where you want to monitor for water leakage.
Version:EZ
Platform Support:Home Assistant, Ewelink
Transmission protocol:Zigbee3.0
Zigbee2MQTT support:Yes
Transmission distance (max) :30meters
Detecting probes:2pcs (bottom)
Battery:1*CR2032
Low battery Alarm:App notification
IP grade :IP66
Certification :CE,Rohs,FCC
