Zigbee Wifi Smart Garage Door Opener DC5V with Door Magnet 433Mhz RF Wireless Controller Work with Tuya Alexa Google Home
You may encounter these problem
Do you always drive to work and forget to close the door?
Your kid forgot to bring his keys when he went out to play
There is a courier and you need to go downstairs by yourself
There's a party at home, a friend is driving, and you need to go downstairs to open the garage door
If you run into these problems regularly, you need a smart switch like this to control your garage door
Are you tired of the inconvenience of traditional switches?then you need such a smart switch.Make your life smarter and more relaxed
Checklist before using the device
You need to have a Zigbee gateway ZIGBEE HUB.
Try to be close to the Zigbee gateway when pairing.
It can not connect directly to a WiFi network
Note before Order, please test compatibility
Please check if your garage controller is compatible with our module.
Take a wire with both ends stripped or a straightened-out paper clip to short-circuit the wall button terminal on the opener (I marked with red color). If the garage door opens or closes, it can work with our smart controller.
Garage door opener controller features:
ZIGBEE Smart Garage Door Controller and Garage Open Close Monitor Compatible With Alexa Echo , Google Home voice control No Hub Require
REMOTE MONITORING: You can open or close the door by the APP. You can check the garage door open or closed state in real time. You can authorize multiple people to access your garage.
EASY TO USE: Instantly control the garage door by tapping the TUYA or SMART LIFE app on your smartphone. Just connect the smart opener to the 2.4G WiFi network.
VOICE CONTROL: You can activate your garage door opener by placing a voice command to your Alexa or Google Assistant device or driving near the garage door
WIDE COMPATIBILITY: You can only use one controller per garage door opener. Compatible with most general garage door openers.Please check the our list.
TIMER FUNCTION: You can set schedules to open and close your garage door. Quick & easy installation as well without the need of a professional. No Hidden Mon
COUNTDONW FUNCTION: You can set the countdown time to close or open the garage door.
Remote control via RF and WIFI
Control your home curtains anytime,anywhere
Real-time door opening and closing display
Timing Function
you can the time to turn on lights and turn on the fans in the office
Family Sharing
Share the control with family member.Enjoy the convenience and happiness together
Hands-Free Voice Control
Compatible with Alexa & Google Home,the smart switch allows you to control lights on/off with your voice
Easy to install
Just aked you connnect the red & black wire with the same port as your wall switch/consloe .and Install the wired door sensor on your garage door
Wired door sensor mount
Find a proper position on the garage door to mount the sensor(You can use the included double-sided adhesive tapes, screws or brackets
for sensor fixation). Please make sure the distance between the two sensors is less than 20mm when the garage door is closed, and the two sensors are well separated when the garage door is open.
With door sensor
