Zigbee Water Sensor Tuya Leak Flood Detector App Remote Monitoring for Kitchen/Bathroom Support Home Assistant
Tips for purchase:
Zigbee version need a tuya zigbee hub to operate.
Tuya Zigbee Water Leak Detector Water Flood Sensor Smart Life App Alert Overflow Water Leakage Sensor for Kitchen/Bathroom
Note:First you need to connect the ZIGBEE 3.0 gateway in order to remote control from your mobile phone via 3G/4G/WiFi.
Description:
[Ultra-long battery life, low battery reminder] Low power consumption technology. The use of high-performance, low-power microprocessor, battery life of up to 1 year, to avoid frequent battery replacement (if the daily reminder of 20 times), the battery power is too low to send timely alarm notification
Specification:
Communication mode:zigbee 3.0
Supply voltage:DC3V (CR2032 battery, included)
Material:Fireproof PC + fireproof ABS
System support:lOS8.0/Android4.0 and above
Application Name:Smart Life/TUYA
Operating frequency:2.4GHz
Wireless technology:Zigbee 3.0
Wireless Distance:Indoor 30~50 metres
Operating temperature:-10℃~50
Packing list:1 sensor, 1 manual (battery included)
When water overflows more than 0.5mm in the detected environment, the sensor
sends an alarm in real time and pushes a message to the mobile app.High Detection Sensitivity
High sensitivity, real-time insight into your home.
