Zigbee Temperature Humidity Sensor for Z2MQTT with NTC Stainless Steel Probe Thermometer Detects Pool Fish Tank Bathtub Freezer
$19.40
Zigbee Temperature Humidity Sensor For Z2MQTT with NTC Stainless Steel Probe Thermometer Detects Pool Fish Tank Bathtub Freezer Aquarium
!!! Important to know before purchase:
*Neither is it not compatible with tuya/smart life,nor Ewelink.If you use it with these cloud platform,some function may not have .
*It is only compatible with zigbee2MQTT via related gateway.Other zigbee gateway is not compatible.
*NOT support ZHA(Zigbee Home Automation)
*NOT support voice assistant
Item: Zigbee Temperature and Humidity Sensor with external temperature probe
Wireless: Zigbee 3.0(need zigbee gateway)
Battery:LR03(AAA) x2 (Not included battery)
Probe Cable Length: 1M
Probe Material:304 stainless steel
Probe Measure Range:-40℃~120℃
Operating Air Temperature:-10°C~60°C
Operating Humidity :0%RH~99%RH
Temperature Resolution :0.1 °C
Humidity Resolution: 0.1%
App: Home Assistant zigbee2MQTT
