Zigbee Temperature and Humidity Sensor Smart Home Hygrometer Thermometer Works with Alexa Google Yandex Alice Ewelink Gateway
Note:Please use the product with one EWelink Zigbee gateway !! (not included)
Product name : Zigbee temperature & humidity sensor
Battery : CR2450 (Included)
Wireless : zigbee 3.0
Temperature resolution : 0.1 C
Humidity Resolution: 3%
【Support Zigbee 2mqtt / Home Assistant】
Note :The zigbee sensor must be used with eWeLink zigbee gateway. Not supported Tuya/Smart Life.
If you need to connect to a third-part smart device, please ensure that your third-party device has a built-in gateway, otherwise it may not be able to be added;
【Simple Design & Easy Installation】It's a battery-operated sensor with low-battery notification on your mobile, adopts adhesive tape on the bottom to easily install it in any corner of your house , as the living room, baby room, bedroom, greenhouse, reptiles terrarium, equipment cabinet to monitor temperature and humidity remotely. forubest store
High accuracy built-in Swiss-made sensor ensures accurate measurement of room temperature and humidity, the temperature is accurate up to ±0.2℃ while the humidity is ±2%RH, and always gives you the latest changes in the environment. which all readings can be checked on eWeLink APP
【Smart Scene To Trigger Devices or Alerts 】You can set a condition in the smart scene that is the fan is turn on/off when the temperature reaches the limit value, or the dehumidifier in your room starts working once the humidity is over higher. You can set a smart scene to trigger alerts through events like high/low temperature, high/low humidity conditions and more. forubest store
【Support other third-part voice assistant 】 You can use one Ewelink gateway to add devices on ewelink app first ,then bind the device with yandex alice , alexa ,google assistant ,or smartthings,then use voice control to ask the temperature and humidity .
【Sharing Control】Simply share the sensor to your family on EweLink APP and they can directly check this temperature and humidity on their mobile phones without pairing it. forubest store
