Zigbee Soil Tester Temperature and Humidity Meter Waterproof Tuya Thermohygrometer Garden Automation Irrigation Detector
Note:It need to work with tuya zigbee hub.
Tuya zigbee Soil Moisture and Temperature Sensor (The connected protocol of soil sensor is Zigbee, and requires Tuya zigbee gateway to connect the mobile phone APP)
Product parameters:
Product name: Tuya Smart Zigbee Soil Moisture and Temperature Sensor
Battery type: 2 pcs 1.5V AA batteries(Not include battery in shipment)
Battery lifetime: Battery of 2000mAh last for over 6 month
Wishmaking Ranges: 0~100%
Moisture accuracy :0~50%(±3%), 50% ~ 100 (± 5%)
Temperature range: -20 ℃ ~ 60 ℃
Accuracy temperatures: ± 1 ℃
Connected protocol: Zigbee
App response time: 60S
Protection level: IP67
Size:Length 180mm,Width 46.5mm,Probe 60mm
Product overview:
Dear users, thanks for using our soil sensor. Please kindly read the manual before using the sensor, it can help you with perfect functions and services.
The soil sensor is designed with a probe which is made of austenitic 304 stainless steel and has the features of good corrosion resistance and toughness. The mobile APP can view real time moisture data, and work with our smartgarden timer to realize automatic intelligent irrigation.
Product features:
1.Monitor real time soil moisture and temperature.
2.Mobile APP to view the historical record curve.
3.Linkage with our smart garden timer to realize automatic irrigation.
4.Powered by two AA batteries, low power consumption and strong battery life.
5.Using highly sensitive probe, fast response, stable and reliable, accuratemeasurement.
6.Quick plug in and easy to measure
Application scenes:
Suitable for various gardening places, satisfy soil moisture measurement in different plantation to provide all-round care for flowers and plants.
Examples: farm/greenhouse/orchard nursery/garden lawn/potted plant/garden horticulture etc.
