Zigbee Soil Temperature and Humidity Tester App Remote Monitoring Thermo Meter Hygrometer Garden Automation Irrigation Detector
*The sensor can work with for tuy zigbee gateway ,support for smartlifeapp ,can work with with Home assistant-zigbee2mqtt .
*Do not support for ZHA ! Do not support for zigbee home automation !
*Do not support for alexa or google assistant voice ,no voice control .
Item: Zigbee Soil Moisture Sensor
Wireless Protocol: Zigbee 3.0(need zigbee gateway)
Soil Moisture Range: 0%~100%
Temperature Resolution: 0.1℃
Humidity Resolution: 1%
Temperature Measurement Accuracy: ±0.5℃
Humidity Measurement Accuracy: ±5%
Working Voltage: DC3V
Standby Current: ≤20uA
Battery Type: 2 x LR03 AAA(not included)
App: for Smart Lif or tuy App
Feature
● [ APP Remote Control ] Can control the device at anywhere and any time.
● [ Work with Zigbee 2qmtt ] Can work with Zigbee 2mqtt.
● [ Fahrenheit &Celsius ] Can be switched to Fahrenheit or Celsius depending on your needs.
● [ Detects humidity and temperature at the same time ] Wireless soil temperature and humidity measuring instrument, which can measure soil humidity and temperature at the same time. forubest store
● [ Water Shortage Warning ] When the soil reaches a state of water shortage, the mobile app sends out a water shortage alert you that it's time to water.
● [ Scene linkage ] It can be linked to automatic watering devices for automatic irrigation.
● [ Wide applications ] It is suitable for a wide variety of soil types, and can be used in potted plants, vegetable greenhouses, farmland, vegetable fields, lawns and other places. forubest store
● [ Family Sharing Function ] Create a smart home with your family. forubest store
● [ Group Function ] You can turn off or turn on group devices together, which is more convenient. forubest store
