Zigbee Rechargeable Roller Shade Blinds Motor for 17 20 25 28Mm Tube Smart Curtain Engine Works with Tuya Smart Life
Note Before Order:
- Tuya Zigbee hub is necessary if you would like to control the curtain via app or voice control.
- Suit for Blinds Max Size: 150cm*200cm blinds and 2kg in weight.
Features:
- Battery Version: This motor is Rechargable, Built-in 800 mAh Battery, Charge by USB port.
- App Control : Tuya zigbee hub is required, you can control motor up or down through Smart Life APP or Tuya Smart App on your mobile phone.
- Voice Control: Simply say to raise and lower your blind. Tell Alexa, Google Home to control your Blind Engine.
- Timer Control: Raise and lower your blinds anytime and anywhere. It is possible to control multiple blinds simultaneously. Set schedule or location for automatic operations.
- Tubular motor for 17mm 20mm 25mm 28mm tube, carry up to 2kg / 2m roller shade.
- RF remote control:
>with 16-channel remote control, can control 15 motors seperately, or control a group of motors together.
