Zigbee Garage Door Controller Module Smart App Remote Compatible with Tuya/Smart Life Alexa & Google Home Voice Control
MOES Zigbee Garage Door Controller Module, Works with Tuya/Smart Life, Alexa & Google Home Voice Control, Smart App Remote
BY-MOES
Packaging List:
Main Module x1
Rail Clip x1
Door Sensor Wire x1
Door Sensor Output Wire x1
Power Cable x1
Signal Output Wire x1
Accessories Kit x1
User Manual x1
BY-MOES
Packaging List:
Main Module x1
Rail Clip x1
Door Sensor Wire x1
Power Cable x1
Accessories Kit x1
User Manual x1
Notice Before Purchase
Note: A Zigbee gateway is required, please purchase separately
Real-time Notification
No matter where you are, the app will receive a notification when the garage door opens/closes (notifications can be turned off in settings)
Real-Time Feedback
The APP page displays the garage door status in real time.
Timing Function
Set a personalized schedule/timer function to open/close the garage door according to your settings.
Smart Linkage: Forgetfulness Alert, Guard Your Home
Link the garage door controller with the smart alarm in the same Smart Life App. When the garage door remains open for too long and triggers a phone notification, the alarm will also activate, providing double protection for your home and property.
Device Notification Settings
Based on your needs, you can enable/disable the following in the APP settings: door open notification, door close notification, and timeout alert. The timeout alert time can be customized. You can also create custom scenes for it.
History Log
The opening or closing of the garage door will be automatically recorded, and you can view the history anytime in the app.
APP Remote Control
When you drive home, you don’t need to get out of the car. Simply use the mobile app to remotely open the garage door, making life more convenient
Share Function
Share the operation permissions of smart garage door module to your family,enjoying smart and convenient life together.
Test Device For Opener Compatibility
3. Press the button on the back of the device; if the garage door activates, it is compatible.
2. Connect the device to your door opener using the included red and black wires; connect the ends to the same terminals where the push button wires on the wall terminate.
1.Power up the device.
Easy to install
Dimensions
