Zigbee Easy Micro Link Intelligent Infrared Detector Ewelink Infrared Sensor Intelligent Linkage
ZigBee Easy Micro Link Intelligent Infrared Detector EWelink Infrared Sensor Intelligent Linkage
1. Measurement of movement
2. Easily installed on walls or any surface using screws or adhesive tape
3. Battery type: CR123A x 1pcs
4. Standby current: 26uA, Alarm current: 120mA - 130mA
5. Battery life: 2500 triggers (1 trigger per day for 7 times, 2 triggers 3 times per day)
6. Sensitivity distance: 6 meters
7. Viewing angle: 110 degrees
8. Operating temperature: 0℃ - 40℃ (32°F - 104°F)
Working humidity: 20% - 85%
Storage temperature: 0℃ - 60℃ (32°F - 140°F)
Product size: 48*48*53MM
Color box size: 85*95*50MM
Number of items per box: 50 pieces per box
Outer box size: 460*270*210MM
Net weight of product: 82g
Gross weight of product: 92g
Gross weight of outer box: 5.2kg
Packaging list: Detector * 1 (with 1 built-in battery) Instruction manual * 1
Note: This product needs to be used in conjunction with a Zigbee gateway. It cannot be used independently.
