Zigbee 3.0 Temperature Humidity Sensor Smart Home Thermometer Hygrometer Works with Home Assistant ZHA Zigbee2Mqtt Alexa Yandex
$9.30
NOTE
1. Zigbee Hub is Required.
2. Please confirm that your Zigbee Hub supports the Standard 3.0 protocol.
3. The display on the PC system page and APP is related to your gateway supplier, not our product. If you have any questions, please contact the supplier of the gateway.
4. Not all Alexa and Yandex support it, please confirm if they support the standard Zigbee 3.0 protocol.
5. There is no tamper proof button.
6. Our products are designed and implemented in strict accordance with the standard Zigbee 3.0 protocol.It has been successfully tested on Zigbee2Mqtt, ZHA, Alexa, and Yandex Alice.If you are using a third-party gateway, please ensure that your gateway supports the standard Zigbee 3.0 protocol.
NOTE: We have found that EWelink or SONOFF gateways do not support the standard Zigbee 3.0 protocol. If you are using their gateways, please contact them to support the standard Zigbee 3.0 protocol.
Work With Home Assistant
Work With Zigbee Home Automation
Work With Zigbee2MQTT
Work With Alexa
NOTE: Not all Alexa supports it, we only support Alexa with built-in Zigbee Hub.
Work With Yandex Alice
NOTE: Not all Yandex supports it, we only support Yandex with built-in Zigbee Hub.
Low Battery Alert
