Zigbee 3.0 Devices Door Sensor
Zigbee Devices
Protocol: zigbee 3.0
Battery is included: Yes
Product size :
*Zigbee PIR Motion Senor (No Lux sensor version): 33mm*33mm*16mm (L*W*H)
*Zigbee PIR Motion Senor (With Lux sensor version): 33mm*33mm*16mm (L*W*H)
*Zigbee Door & window Sensor : 50mm*25mm (L*W), 30mm*14mm(L*W)
*Zigbee Temperature and humidity sensor: 40mm*40mm*13mm(L*W*H)
*Zigbee water leak detector: 50mm*50mm*16mm(L*W*H)
*Zigbee Wireless Switch scene button: 50mm*50mm*13mm(L*W*H)
*Zigbee mini smart switch: 40mm*40mm*20mm(L*W*H)
*Zigbee vibration sensor : 40mm*40mm*13mm(L*W*H)
*Zigbee Gateway(zigbee+bluetooth): 50mm*50mm*11mm(L*W*H)
Note: There may be a bit difference in manual measurement size, please refer to the actual product. Thank you.
The product need to work with one zigbee gateway ,zigbee hub need to purchase additionally.
