Upgrade Your Home with the B29C-Tuya Zigbee Smart Temperature and Humidity Sensor - Perfect for Alexa & Google Assistant!
Smart Integration: Requires a Tuya gateway to function, seamlessly integrating with your smart home system. Compatible with for Alexa and Google Assistant for easy voice control.
Real-Time Updates: Features an automatic update cycle every 30 minutes. It sends immediate updates to your smartphone if temperature changes exceed 0.5°C or humidity varies by more than 5%.
Technical Specifications: Powered by a DC3V CR2032 battery, with a static current of ≤20uA and a working current of ≤15mA. The sensor operates within a temperature range of -9.9°C to +60°C and can detect humidity from 0% to 99% RH.
Versatile Installation: Can be mounted on the wall or placed on a desk. Easily switch between Celsius and Fahrenheit with a short press, or enter configuration mode by holding the set button for 3 seconds.
Color: White
Material: ABS
Package Contents:
1 x Thermometer
Color: White
Material: ABS
Package Contents:
1 x Thermometer
