Tuya Zigbee3.0 Smart Vibration Alarm Sound Alert on Shock/Movement Detection, Home Assistant Compatible Security Sensor
Lincukoo Tuya Zigbee3.0 Smart Vibration Alarm Sound Alert on Shock/Movement Detection, Home Assistant Compatible Security Sensor
Important Note:
The TZ version only be used on Tuya or Home Assistant platform, need zigbee gateway to use
a.Go to the link to buy the Tuya gateway
b.Go to the link to buy the Home Assistant gateway
--This vibration alarm sensor can sound alarm and send notification by mobile phone when any vibration/movement is detected, it can be used to home security, for example, stick it on window, any open or shock will be detected and sound alarm so that to deter the action.
--As your need, adjust the sensitivity (low-mid-high) and mute the sound alarm by button or App
--Connect to internet, you can know at anywhere whether the object you are concerned about (such as door, window, safe, folder) is opened, broken, moved or shaken. and linkage with other devices, even if it is offline, the 120db sound alarm still can deter similar actions which not be allowed
Product information :
Version:TZ
Platform Support:Tuya, Home assistant
Transmission Protocol:Zigbee3.0
Zigbee 2 MQTT support:Yes
Transmission distance(max):40meters
Sound alarm:120db
Sensitivity adjustable:Button or App
Battery :2*AAA
Certification :CE,Rohs,FCC
