Tuya Zigbee/ Wifi Smart Temperature Humidity Sensor Indoor Hygrometer APP Remote Real-Time Monitoring Works with Alexa Google
Note: zigbee sensor needs to be used with zigbee gateway
Wifi sensor does not need to be used with zigbee gateway
1. APP remote real-time monitoring-- You can monitor the temperature and humidity of your home in real time from anywhere.
You can also view historical temperature and humidity changes
2.Intelligent Linkage--You can set up the smart linkage function and associate it with other Tuya devices in your home, such as smart IR remote control.For example, the air conditioner will be on and turn to specified temperature automatically when the room temperature surpass 28℃. And the humidifier will spray when the humidity is lower than 20% RH.
3.Low battery alarm--The battery level can be monitored.
4.Temperature Unit Selection in APP-- You can choose ℃ or ℉ as the temperature unit through app.(Note:Zigbee Version does not contain this feature)
5. Third-party Voice Control-- Works with amazon alexa, google assistant.
6.Share devices-- You can share your added devices with your family members, so they can also monitor the ambient environment.
Description:
Material : ABS
Product Weight: 19g
Battery:LR03-1.5V/AAA*2
Wi-Fi frequency: 2.4GHZ IEEE 802.11 b/g/n
Zigbee : zigbee 3.0
Temperature Measure Range: -20°C ~ 60°C
Humidity Measure Range: 0% RH ~ 100%RH
Temperature Measure Accuracy: ±1°C
Humidity Measure Accuracy: ±5%RH
