Tuya Zigbee/Wifi Smart Door Sensor Garage Door Window Open/Closed Detectors Smart Life APP Remote Control via Alexa Google Home
Description:
【2.4GHz WiFi One-Key Connect Easy Setup】 Do not need home gateway, you can easily achieve the intelligent control of home appliances, simple operation, easy to use.2.4G Hz protocol is more stable, faster and more convenient
【Detect door/window status 】When the door/window is opened or closed,the device triggered and push notification to the phone.
【Linked alarm with more sensors】 Set up the scene: away from home mode, if someone breaks in, the the device triggered and push notification to the phone., and the IP camera (not included) will shoot the video. When someone opens the door, the light turns on automatically.
【APP Remote Control 】Home is in the hands,whenever and wherever
【Easy to install】Small size,easy to install Adhesive installation,can be flexibly placed in various doors, windows,drawers,etc,without destroying the appearance and structure of the original furniture
Input voltage:3V LR03
Quiescent Current:≤45uA
Alarm Current:≤130mA
Low power undervoltage:≤2.4V
WiFi:802.11 b/g/n
Magnetic control distance:≥15mm
Battery: DC 3V LR03(AAA battery,not included)
Alarm mode: mobile phone APP notification push(Smart Life/Tuya Smart)
Size: Main body: 68*23*19mm
Permanent magnet: 43*10*14mm
Package Included:
1*sensor,1*manual,1*sticky
