Tuya Zigbee Water Leak Sensor Smart Leakage Detector Built-In Smart Siren 85Db Alarm Sound for Smart Home Security System
ITEM DESCRIPTION
Detect Water Leakage Remotely
Assist you to monitor your home security wherever you are.
Leaking and Dripping Detection
The highly sensitive sensor effectively monitors for any water leaks or dripping, ensuring prompt detection and notification.
Alert in Real-time
With its butil-in siren, you can hear the alarm when this leakage monitor detects the leaking/dripping.
Smart Automation Scenes
Integrate this smart water leakage sensor with other Tuya smart devices for seamlessly home automation. For instance, close the water valve in case of kitchen sink leaks or trigger window closure when water is detected on the windowsill.
Tuya ZigBee Hub Required
Tuya ZigBee gateway is required when you pair this smart water leak sensor.
More Features
☆Batteries Included
Note
It is not completely waterproof. Please ensure that the area near the hole of the alarm is dry.
