Tuya Zigbee Water Leak Detector Water Flood Sensor Smart Life App 2MQTT Alert Overflow Water Leakage Sensor for Kitchen/Bathroom
Choose the right version, place it where leaks may happen, and enjoy peace of mind every day.
🔌 Important: ZigBee Hub Required
⚠ This sensor does NOT connect directly to Wi-Fi
⚠ A ZigBee gateway / hub is required (sold separately)
❌ Does NOT support:
ZHA/Ewelink
🔹 Zigbee Tuya Version
Best for everyday users & simple setup
Works with: Tuya / Smart Life App
Ideal for standard smart home users who prefer convenience
❌ Does NOT support:
ZHA/Ewelink
💧 ZigBee Smart Water Leak Sensor
Detect Leaks Instantly · Protect Your Home 24/7
-Water leaks often happen silently — under sinks, behind washing machines, or in basements.
This ZigBee Smart Water Leak Sensor detects leaks at the very first sign of water and sends instant alerts to your phone, helping you prevent costly damage before it’s too late.
🚨 Instant Leak Detection & Real-Time Alerts
-Detects water leakage, overflow, or immersion immediately
-Sends instant app notifications when water is detected
-Stay informed anytime, anywhere, even when you’re away from home
-View alert history to track and manage past events
📱 Smart App Control · Easy Monitoring
-Remote monitoring via mobile app
-Device grouping supported — manage multiple sensors easily
-Clear status display and alert records at your fingertips
-Simple setup and user-friendly operation
🔋 Low Power Consumption with Battery Alerts
-Powered by 1 × CR2032 battery (included)
-Ultra-low power ZigBee design for long battery life
-Real-time battery level monitoring in the app
-Low-battery warnings ensure uninterrupted protection
🌧 IP66 Waterproof & Dustproof · Built for Any Environment
-Designed for reliable performance in wet and harsh conditions:
-Kitchen sinks & dishwashers
-Bathrooms & washing machines
-Fish tanks & water tanks
-Basements, warehouses, and storage rooms
-Pipes, boilers, and utility areas
-Compact size (≈ 50mm × 16mm), discreet and easy to place anywhere.
⚙️Dual Monitoring Modes for Flexible Use
-Leak / Overflow Alarm – instantly detects unexpected water leaks
-Water Immersion / Low Water Detection – ideal for tanks and containers
-One sensor, multiple applications.
🛒 Why Choose This Water Leak Sensor?
✔ Early leak detection prevents property damage
✔ Stable ZigBee 3.0 connection
✔ Low power, long battery life
✔ Wide application scenarios
✔ Two versions for different smart home systems
Package included:
1*sensor
1*manual
