Tuya Zigbee Vibration Siren Sensor Smart Sound Light Siren Detector with 110Db Audio Alarm Rapid Detection for Home Security
Tuya Zigbee Vibration Siren Sensor Smart Sound Light Siren Detector with 110dB Audio Alarm Rapid Detection for Home Security
There are 2 connection protocols:
For Z2M: only support Home Assistant Zigbee2MQTT, please note Z2M not ZHA. Also cannot work with Tuya/smart life App!
For Tuya zigbee: Both Support Tuya/smart life App and Z2M, must be use a Tuya zigbee gateway/hub, cannot work with wifi directly!
Specification
Product Name: Smart Sound&Light/ Vibration Siren Sensor
Operating Current: ≤200mA
Standby Current: ≤10uA
Standby Time: ≥12 Months
Built-in Siren: ≥110dB
Power Input: DC3V LR03(not included)
Operating Temperature: -10°C- 55°C
Operating Humidity: 0% ~99% RH
Product Size: 72x32x24mm
Communication Protocol:Tuya zigbee and zigbee2mqtt version both are write Zigbee 3.0(need zigbee gateway)
App Name: Smart Life/Tuya; Home Assistant Z2M(not recommend to use ZHA)
Function description of vibration detection alarm:
1. After the device is powered on, it will enter the vibration detection function only after 30 seconds and two beeps. The indicator light will flash once every 5 seconds, indicating that the device has entered the armed mode.
2.In the app, you can set the device status to armed/disarmed. Only when in armed mode, the siren will sound when the device vibrates.
3. Arter the device is armed, the indicator light will flash once every 5 seconds.
4. This device features real-time online functionality, allowing users to remotely issue commands to the sensor in real time, such as sounding the alarm to eliminate the alarm sound, and setting up automat-ed scenarios for linkage.
5. After the equipment vibrates, an alarm will be triggered. The factory default alarm duration is 60 seconds, which can be adjusted on the APP.
6. Clicking the "SET" button can switch the alarm sound to "Siren" or "Music", "Mute".
Function description of sound and light alarm:
1. The device features real-time online functionality, allowing users to set up automated scenarios for interconnection, such as sounding an alarm or ringing a doorbell.
2. The factory default alarm sounding time is 60 seconds, which can be set on the APP.
3. Click the "SET" button to adjust the alarm volume, with options including "highest", "medium", "low", and "mute".
