Tuya Zigbee Vibration Door Window Sensor Smart Door Contact Sensor Smart Life Home Assistant Zigbee2Mqtt App Open Close Alert
$51.92
Color: 1 Piece
Note:this is the zigbee sensor it need to work with the zigbee hub
1. Vibration & Door Window Detection
This Zigbee vibration door window sensor combines shake detection and open/close detection in one compact device, helping monitor doors, windows, garage doors, storage rooms and other important areas.
2. Real-Time App Alerts
When vibration is detected or the door/window status changes, the sensor can send real-time alerts through a compatible smart home app, so you can check activity anytime from your phone.
3. Works with Zigbee Smart Home Systems
Designed for Zigbee smart home setups. Compatible with Tuya, Smart Life, Home Assistant and Zigbee2MQTT through a compatible Zigbee gateway. Alexa and Google Home support depends on your gateway and smart home setup.
4. Smart Automation Trigger
Use the sensor as an automation trigger for lights, alarms, cameras, scenes or routines. For example, turn on a light when a door opens, or trigger a notification when vibration is detected.
5. Compact Wireless Installation
Small, clean and wireless design for easy installation on doors, windows, garage doors, cabinets, storage rooms and other indoor areas. No complicated wiring required.
