Tuya Zigbee Smart Scene Switch 4 Gang Portable Mini Design for Home Smart Life Remote Control Automation Scenario Switches
$23.45
Tuya ZigBee Smart Scene Switch 4 Gang Remote Portable for Smart Home Automation Scenario Remote Control With Alexa Google
Description:
This product needs to be used with tuya zigbee gateway!
1.Smart automate the Tuya ZigBee wireless scene remote switch to any Tuya smart devices in Smart Life App to set various scenes for your smart life.Tap-to-run to get another easier control for all Tuya smart devices with one key on the remote switch.Each switch button can satisfy multiple needs, realizing different scenes.Imagine the smart linkage to create an infinite space with the wire scene switch.
Note:ZigBee hub required for adding the switch to it for normal use.
2.Three pairing modes for each button to achieve 12 scenes from one 4 gang scene remote,such as away mode,home mode,movie mode in each button,etc.To create any smart automation as you want on your smart phone app to start your another intelligent lifestyle,no more voice command needed,no more time to open your app,only one touch required,when you are tired from one-day work.
3.Compact mini design for portable: it is a wireless wall remote when attached to the wall with the wall bracket, remote control for portable when unattached. It can be conveniently carried to the balcony, bedroom, kitchen, and more due to its compact size.
4.It can be used in numerous scenes with smart devices: speed up smart device responding time, provide more fluid control, remove the dependence on a WiFi network only.
5.Fix it anywhere you like with double-side tape for the wall bracket or just put it anywhere for easy touch; Low power consumption with long battery life;no wiring needed for simple use,easily establish multiple control to realize fast and easy upgrades.
Note:Intelligent linkage to Tuya smart devices for normal use only,can not be used alone without Tuya smart devices.
Input:LR 23A 12V(battery included)
Dimension:110*37mm
Package Included:
Wireless scene switch*1
Manual*1
