Tuya Zigbee 3.0 Temperature Humidity Sensor Smart Home Automation APP Remote Connect Work with Alexa Google Home Assistant
Product Features
1.Accurate Measurement: Reliable sensor for precise data.
2.APP Monitoring: Real-time temp & humidity tracking with graphs.
3.Smart Integration: Works with Tuya products for smart automation.
4.Voice Control: Compatible with Alexa and Google Assistant.
APP Monitoring
You can view the historic curve of the temperature and humidity in the app, and export to your email address.
Smart Integration
Such as triggering the air conditioner via our universal remote control when the temperature hits 32.6°C.
Voice Control
The sensor supports Alexa, Google Home Assistant. You can check the current temperature and humidity by voice.
Low Battery Automatic Reminder
When the battery power is low, it will push alarm message via app, remind you to change the battery.
Temperature & Humidity Alarm
You can preset the range for the temperature and humidity in the Scene page, when the temperature or humidity reaches the range, you will receive alarm message on mobile.
