Tuya Zigbee 3.0 Door Window Sensor IP65 Waterproof & Non-Waterproof Options Magnetic Contact Alarm Alexa Yandex ZHA
Product Features
1.Instant Mobile Alerts
When the smart door/window sensor detects an open/close event, you will receive an instant alert on your phone via the app.
2.Smart Scene Automation
Create custom smart home automation scenes in the Tuya app. For example, when the door is opened, trigger a smart alarm.
3.Versatile Applications
Meets your needs in various scenarios
4.Real-Time Monitoring
Check the sensor’s status on your phone anytime, anywhere.
5.History Logs
The Tuya app automatically records every open/close event of the door/window sensor. You can remotely view the event history log at any time.
6.IP65 Waterproof Design
The IP65 waterproof design makes the door/window sensor more durable, suitable for monitoring doors and windows in humid or dusty environments.
7.Pet Escape Prevention
Install it on a pet door. When your pet opens the door to go out alone, the sensor instantly detects and sends an alert, preventing your pet from leaving home without your knowledge.
Zigbee3.0 NOTE
1,Zigbee Hub is Required.
2,Please confirm that your Zigbee Hub supports the Standard 3.0 protocol.
3,The display on the PC system page and APP is related to your gateway supplier, not our product. If you have any questions, please contact the supplier of the gateway.
4,Not all Alexa and Yandex support it, please confirm if they support the standard Zigbee 3.0 protocol.
5. There is no tamper proof button
6. Our products are designed and implemented in strict accordance with the standard Zigbee 3.0 protocol.It has been successfully tested on Zigbee2Mqtt, ZHA, Alexa, and Yandex Alice.If you are using a third-party gateway, please ensure that your gateway supports the standard Zigbee 3.0 protocol.We have found that EWelink or SONOFF gateways do not support the standard Zigbee 3.0 protocol. If you are using their gateways, please contact them to support the standard Zigbee 3.0 protocol.
If you are using Tuya Zigbee gateway, we suggest that you purchase Tuya zigbee version
