Tuya Wifi/Zigbee Smart Vibration Sensor Home Security Protection Smartlife App Real-Time Remote Monitor Alarm Notification
$19.69
Note: All Zigbee products need to be used together with the Zigbee gateway
1. APP Remote Real-time Monitoring
Monitor the condition of the house remotely through the app and save records
2.Vibration Alarm
When the sensor falls or detects vibration, it will send an alarm notification to your smartphone, allowing you to immediately check the situation at home and ensure its safety
3.Sensitivity Adjustable
You can adjust the sensitivity of the vibration sensor according to different usage scenarios
4.Intelligent Linkage
It can be linked with other Tuya intelligent products. For example, linkage with smart curtain switch: when the sensor detects vibration, open the curtains
5.View History Recods
Support recording the historical data of sensor operation, you can view the sensor's past work records on the mobile app
6.Low Battery Reminder
When the battery is low, the sensor will send a low battery reminder to your smartphone, and then you can replace the battery for it to always ensure family safety
7.Low Power Consumption
The sensor is powered by two AAA batteries, and usually two new battery replacement can keep it working continuously for 5-8 months
8.Sharing Function
You can share the sensor with your family and friends, so they can also check the working status of the sensor like you do
Product Parameters
Working voltage: DC 3V
Standby current: ≤ 10uA
Alarm current: ≤ 20mA
Wireless type: 2.4G WiFi/ZigBee 3.0
Transmission distance: 10-30 meters (indoor obstacle free)
LED indicator light: Yes
Installation method: 3M tape or screws
Battery: 1.5V AAA dry battery * 2(included)
Working temperature: -10 ℃~50 ℃
Working humidity: ≤ 95% (no condensation)
Update frequency: half an hour
