Tuya Smart Zigbee Temperature and Humidity Sensor Battery Powered Indoor Mini Hygrometer Work with Alexa Google Home
Notes: If you choose this ZigBee Sensor, you need a ZigBee getaway to make it work.
Tuya Smart ZigBee Temperature and Humidity Sensor
A Tuya ZigBee Wireless Gateway Hub is a must to work with the temperature and humidity sensor,as well as a variety of ZigBee smart products, which is proved to be the bridge and control center for smart homes and plays an irreplaceable role for all ZigBee products and realizes the whole intelligent linkage of your house.Simply add the sensor into the ZigBee hub after adding the hub into Smart Life/Tuya App.
Real-time notification
Real-time perception of temperature and humidity changes and real-time report to your smart phones with Smart Life Tuya App supported.View history record in App for smart controls for your house temperature and humidity.Monitor your house temperature and humidity no matter where you are.
low power consumption
ZigBee technology with low power consumption microprocessor for long standby.Designed with low voltage monitoring reminder function in App for real-time power supply for your sensor.Battery powered with long battery life.(Battery not included in the package.)
Scene linkage
Added with temperature compensation technique with smart scene linkage to your air conditioning and humidifier,offering your house with the most comfortable temperature and humidity to enjoy our smart life.
Easy to Use
Widely used in various places and easily stick it to the wall with the sticker for simple installation,light and compact.Easy set up and configure to your Smart Life App for convenient control
Product name: Temperature and humidity sensor
Battery type: CR2045(included)
Temperature detection range:‒10℃ ~ +55°C
Humidity detection range: 0%~95%RH
Temperature detection accuracy:±0.5℃
Humidity detection accuracy: ±3%
Wireless protocol: ZigBee(need gateway)
Product size: 37*11.6mm
Package List:
Sensor*1
User manual*1
Reset pin*1
