Tuya Smart Zigbee Temper & Humidity Sensor Smart Life App Home Automation Indoor Humiture Monitor Works with Alexa Google Home
Tuya Smart ZigBee Temperature and Humidity Sensor Smart Life APP Home Automation Indoor Humiture Monitor Detector Works with Alexa Google Assistant
Product Features:
1. High Temperature Humidity and Low Temperature Humidity Alarm:
Once the set value is exceeded, the alarm will be pushed automatically.
2. Real-time Monitoring:
Battery powered AAA 1.5V * 2 (excluding batteries), low power consumption.(The data update frequency is 1-120 minutes, and you can select the update frequency as needed. The smaller the value, the shorter the actual battery life.)
3. Temperature and Humidity Curve Chart:
Record the temperature and humidity changes on the APP and present them graphically for you. More intuitive to let you know recent data changes.
4. Scene Linkage:
This sensor can be used as a temperature and humidity data source for graffiti intelligence, smart life, Amazon Alexa, and Google Home. You can perform many automated processes based on data sources.
5. Third-party Voice Support:
This sensor supports Amazon Alexa and Google Home Assistant. You can hear the current temperature and humidity through voice.
Product Parameters:
Note: It can not be used alone and needs to be paired with a ZigBee3.0 gateway.
APP Home Platform:Smart Life APP / Tuya APP
Work With: Alexa and Google Assistant
Power Supply: AAA 1.5V * 2 (not including battery)
ZigBee Frequency: IEEE 802.15.4
Temperature measurement range: - 20 ℃~60 ℃
Temperature accuracy: ±1℃
Humidity measurement range: 10%~99% RH
Humidity accuracy: ± 5% RH
Size: 71 * 25 * 20mm
