Tuya Smart Zigbee Soil Tester Temperature and Humidity Meter Thermo Hygrometer Garden Automation Irrigation Detector
Note:It need tuya zigbee hub to work.won't work without hub.
This flower plant monitor can help you care your plant with ease, it can detect the ambient temperature and soil moisture. Made of PC and ABS material, with high impact resistance, heat resistance, low temperature resistance, nice chemical resistance and electrical properties. BT connection, BT 4.1 version, cellphone APP control, support for both iOS and Android system. Multi-scene application: plug and plays, suitable for indoor potted plants, green plants, greenhouse, etc.
Features:
1. Made of PC and ABS material, with high impact resistance, heat resistance, low temperature resistance, nice chemical resistance and electrical properties.
2. High accuracy, support the detection of the humidity and ambient temperature in the soil of green plants, lawns, etc.
3. BT connection, BT 4.1 version, support for both iOS and Android system.
4. Cellphone APP control, accurate readings, so that users know the specific situation of the soil at any time, to solve the traditional temperature and humidity is not easy to read the problem.
5. Mobilephone APP displays the soil temperature and humidity in the detection, and the indicator lights up when 3%6. The upper LED indicator is designed to remind users to water in time.
7. Multifunctional design, statistical temperature and humidity function with low battery reminder.
8. Multi-scene application: plug and plays, suitable for indoor potted plants, green plants, greenhouse, etc.
Note:
1. Before installing this product in the ground, be sure to cleanup the outer surface of the device.
2. Insert soil moisture sensor in the ground not less than 2/3. Ensure maximum exposure to the topside of the unit. Check for absence of water on a soil moisture sensor.
Protocol:Zigbee
Material: PC+ABS
Color: blue
Battery: 2 * AAA battery (not included)
APP: SmartLife
Indicator: lights up when 3%
Item size: 161 * 31.5 * 19mm / 6.34 * 1.24 * 0.75in
Item weight: 35g / 1.23ounce
Package size: 35 * 23 * 168mm / 1.38 * 0.91 * 6.61in
Package weight: 50g / 1.76ounce
