Tuya 16A WIFI Zigbee 3.0 Mini Smart Life APP Remote DIY Timing Relay Wireless Control with Alice, Alexa, Google Assistant
Product description
Note: Zigbee mini switch needs to be used with zigbee gateway
This Zigbee product standard 3.0 can be used with the following gateways
Samsung SmartThings Hub
Amazon Echo
Philips Hue Bridge
FEIBIT
REXENSE
All Zigbee 3.0 Gateway
Home Assistant(HA)
Tasmota
★Mobile APP Remote Control. --Whether you are in a company, a park or even another city, you can control the switches at home through the mobile APP
★ Voice control via Alexa, goolgle home , or Yandex Alice--"Alexa, turn on the bedroom lights." “OK.”
Support voice assistant such as Yandex Alice, Alexa, Google Home etc. Make your life easier
★Timing/Countdown/Schedule-- You can set the timer: "Turn on the living room lights at 18:00"
Or you can set: "Turn off kitchen lights after 30 minutes"
Timing and countdown functions help you remember the rhythm of life
★State memory. --Unexpected power outage? It doesn't matter, turn on the state memory function, after the power is restored, it can automatically restore to the state before the power failure
★Sharing and Group control. --The main account can be shared with other family members, and the functions and settings are completely retained and copied; The switches can be grouped to achieve unified control.
★Three wiring methods. --Support 2-way/1-way/non switch, there is always one for you
