Transform Your Space with the Smart Mic Controller RGB IC Light Strip - Perfect for Music Dynamic Modes and DIY Customization!
🌟ESP32 Chip with Mic: Efficient processing chip, and also has microphone function, can use music dynamic mode.
🌟Music Dynamic Mode: The GLEDOPTO ESP32 WLED light strip controller comes with a built-in microphone, enabling music dynamic mode. When you play music, the light strip automatically adjusts the lighting effect based on the rhythm and sound changes, creating a more vibrant and lively atmosphere. Whether it's at home gatherings or party events, it can bring you more fun.
🌟WiFi Network Control: The GLEDOPTO ESP32 WLED light strip controller can be connected through WiFi and controlled directly using the WLED app, without the need for an additional gateway device. This means you can control your light strip anytime, anywhere using your smartphone or tablet, making it convenient and easy.
🌟Rich Lighting Modes: This controller has more than 100 dynamic modes built-in, allowing you to choose the appropriate mode based on different scenes and preferences. From soft gradient colors to jumping flash effects, this controller can meet various lighting needs.
🌟DIY Lighting: The GLEDOPTO ESP32 WLED light strip controller supports customized lighting effects. You can create unique lighting effects by adjusting color, brightness, speed, and other parameters, making your space more personalized.
🌟Multiple Light Strip Compatibility: This controller is compatible with various types of light strips, such as WS2811, WS2812, SK6812, TM1814, WS2813, WS2815, and more. Regardless of what type of light strip you have, it can easily be paired with this controller.
Q&A or more info, please contact us on line, and we will answer you in time.
Product Name:ESP32 WLED Strip Light Controller with Mic
Model No.:GL-C-010WL
Voltage: DC 5-24V
IC Quantity: 800 Max
Total Current: 10A Max
Operating Temperature:-20-45°C
Supported Strip: WS2811, SK6812, SM16703P, WS2812, etc
1pcs* ESP32 WLED Strip Controller with Mic
1pcs* User Manual
1pcs* 3cm Stricker
