TNCE Tuya Wifi/Zigbee3.0 Smart Temperature and Humidity Sensor Indoor Hygrometer Controller Monitoring Work with Alexa
Tuya Wifi/Zigbee3.0 Smart Temperature And Humidity Sensor Indoor Hygrometer Controller Monitoring Work with Alexa
By TNCE
Note: If you choose zigbee version, you need a zigbee gateway to use it normal. This zigbee3.0 gateway needs to be purchased additionally.
roduct parameters
Battery: LR03 1.5V AAA * 2 (not include in package)
Wireless type: 2.4Ghz WIFI or zigbee
Measure Range: -20°C-60°C ; 0%RH-100%RH
Measure Accuracy: ±1°C ; ±5%RH
Packing List:
sensor * 1
Instruction manual * 1
Double-sided tape * 1
Reset ejector pin * 1
APP remote control
View current temperature & humidity through and history
Temperamre Unit Selection
You can choose °C or °F as the temperature unit through app.
Smart Linkage Function
DIY different smart automation/tap to run scene
Voice control
Temperature and humidity information can be obtained at any time through Alexa or Google Home voice assistant.
Device Sharing
Sharing the Temperature & humidity Sensor with family members by tuya smart/Smart Life app to control together.
Alarm management
If the detected temperature/humidity value exceeds the set value, APP will receive an alarm notification message.
