Smart Zigbee3.0 Tiny Door/Window Sensor Door Open Closed Wireless Alarm for Zigbee2Mqtt Home Assistant or Ewelink
$15.31
Lincukoo ZigBee3.0 Tiny Door/Window Sensor Smart Home Wireless Door Open Closed Alarm System for Smart Life or Ewelink Home Assistant Door and window magnets
Important Note:
The HZ version only be used on Home Assistant or Ewelink platform, need zigbee gateway to use
a).Go to the link to buy
Tiny Door/Window Sensor Description:
-This sensor can detect the status(open/close) of door, windows, draw, cabinet etc, and send notification to mobile phone so you may knowabout their situation where ever you are.
-Its tiny size (ultrathin) is suitable any small spaces such as draw, wardrobe
-Use the latest Hall magnetic component to against fallen damage, so even if it be knocked off, you can still install and use it again
-Support linkage with other devices through gateway, such as turn on/off light……
