Smart Zigbee 3.0 Temperature and Humidity Sensor Tiny Remote Monitor for Smart Home Assistant Zigbee2Mqtt Ewelink
Lincukoo Smart Zigbee 3.0 Temperature And Humidity Sensor Tiny Remote Monitor for Smart Home Assistant zigbee2MQTT eWelink
Important Note:
The EZ version only be used on Home Assistant or Ewelink platform, need zigbee gateway to use
Tiny Temperature & Humidity Sensor Description:
-This sensor can detect the real-time temperature & humidity, In App, you may see the current value or the history record to know about the temperature & humidity changing aroundyou
-The High accuracy sensor chip supports that the detect range is -20-60°C(±0.3°C) and 0-100RH(±3RH)
-If you want to use it at a fix point, you can use adhesive tape or screw, if you want to use it on different positions, you can also hang it at you need.
-2*AAA batteries can be used for 2yeas at least (the duration may vary depending on the usage environment), even if low battery alarm, stillcan last for 1-2months.
-Support linkage with other devices through gateway, such as turn on/off the air-conditioner, humidifier……
Product information:
Version:EZ
Platform support:Home Assistant, Ewelink
Transmission Protocol :Zigbee3.0
Zigbee to MQTTsupport :Yes
Transmission distance(max):30meters
Temperature/Humidity alarm setting :No
Battery:2*AAA
Low battery alarm:App notification
IP grade :IP64
Install mothed:Double-sided tape or hanging
Certification :CE,Rohs,FCC
