Smart Temperature Humidity Sensor Tuya Zigbee3.0 Zigbee 2 MQTT Suppor Display the Temperature Home Assistant
$46.67
Lincukoo Smart Temperature Humidity Sensor Tuya Zigbee3.0 Zigbee 2 MQTT suppor display the temperature Home Assistant
--It can detect and display temperature & humidity, internet time, comfort indicator in real time, linkage with other devices to bring you a comfortable environment in room
--It can be installed by magnetic, double-sided tape, or just place on table can used in any place at home
--Its detection range is-20-60°C(accuracy:±0.3°C) / 0-100%RH(accuracy:±3%), can sound alarm when reached your setting value
--You may check the curve of history record by day, month or year to know about the changing of temperature & humidity
--You may also set the temperature unit (C°/F°), the accuracy, the alarm function in setting page
--High-capacity batteries can be used for 1year at least (the duration may vary depending on the usage environment) even if low battery alarm, still can last for 1-2months.
Product information:
Version:T04TZ
Platform Support:Tuya,Home Assistant
Transmission Protocol:Zigbee.30
Zigbee 2 MQTT support:Yes
Transmission distance(max):40meters
Detection Range:-20-60°C(±0.3)/0-100RH(±3)
Setting and calibration:Yes
Sound alarm:Yes
Battery:2*AAA
Low battery alarm:App notification
Install mothed:Magnetic, double-side tape
