Smart Switch Mini Home Assistant Zigbee Scene Button Switch for Home Automation Multi-Scenario Linkage Switch Support
Lincukoo Smart Switch Mini Home Assistant Zigbee Scene Button Switch for Home Automation Multi-Scenario Linkage Switch support eWelinkAPP
Important Note:
The EZ version only be used on Home Assistant or Ewelink platform,
This mini switch has three functions—single click, double click, long press, to provide 3 ways to control kinds of devices,for example :single tap to control the first light, double tap to control the second light, long press to turn off all of lights.
Any point on the entire surface can respond accuracy becauseits exquisite ergonomic design, whatever click gently or slap heavy
The bottom anti-slip pad can reduce movement and make it easier to use
The CR2032 battery can support 50000 clicks (depending on the actual environment) and support low battery alarm
Product information:
Version:EZ
Platform support:Home Assistant,Ewelink
Transmission Protocol :Zigbee3.0
Zigbee to MQTT support :Yes
Transmission distance(max):30meters
Function:Single click, Double click, Long press
Battery:1*CR2032
IP grade:IP64
Anti-slip:Yes
Certification :CE,Rohs,FCC
