Real-Time Outdoor Temperature Humidity Monitor - IP65 Waterproof, Wifi/Zigbee Enabled for Smart Environments
NOTE:
Bundle 1 is the Wi-Fi version and requires a 2.4GHz Wi-Fi network to function.
Bundle 2 is the Zigbee version and only works with the Tuya Zigbee gateway.Please choose carefully before purchasing.
Product Features:
1. [IP65 Waterproof and Anti-Coverage] Suitable for outdoor installation, dual-mode Wi-Fi + Bluetooth: Faster network connection. Network connection speed is 2 times faster than Wi-Fi only.
2. [High/Low Temperature Alarm]: The phone will alert you if the set temperature value is exceeded.
3. [High/Low Humidity Alarm]: The phone will alert you if the set humidity value is exceeded.
4. [Real-time Monitoring]: Battery powered by AAA 1.5V*2 (excluding batteries), low power consumption, approximately one year of use with default system settings.
Default data update frequency is 60 minutes, or temperature ±0.6 (adjustable via APP), humidity ±6% (adjustable via APP). The update frequency can be selected as needed. Lower values will shorten actual battery life.
5. [Temperature and Humidity Curve]: Records temperature and humidity changes on the APP and presents them graphically. Provides a more intuitive understanding of recent data changes.
6. [Multiple Installation Methods]: Can be placed directly on a table or affixed to a wall. The absence of a data cable makes it more convenient and aesthetically pleasing.
7. [Scene Integration]: This sensor can serve as a temperature and humidity data source for Tuya Smart, Smart Living, Amazon Alexa, and Google Home. You can execute many automated processes based on this data source. Note that this function requires a universal infrared remote control or a Wi-Fi switch; please contact customer service to purchase one.
8. [Temperature Unit Switch]: The sensor features Celsius and Fahrenheit temperature conversion. You can select the unit you want to display. The switching speed is related to the set data update frequency. You can first select an update frequency of one minute, after which the temperature will switch to the new unit, and then switch the data update frequency to the desired time.
9. [Third-Party Voice Support]: This sensor supports Amazon Alexa and Google Home Assistant. You can hear the current temperature and humidity via voice.
Product Parameters:
Material: ABS
Battery Type: AAA 1.5V*2 (batteries not included)
Wi-Fi Support: 2.4G IEEE 802.11 b/g/n
Temperature Measurement Range: -10℃~55℃
Temperature Accuracy: ±0.6℃
Humidity Measurement Range: 10%~99%RH
Humidity Accuracy: ±6% RH
Product Dimensions: 73.3*27.3*22.8mm
Packaging Dimensions: 87*32*28.8mm
Product Weight: 31g (including packaging)
Product Features:
Product Parameters:
Material: ABS
