MANHOT Zigbee Smart Solar Soil Sensor IP66 Waterproof Temp Humidity Detector Monitor Home Garden Plants Cultivation Smart Life
$67.96
Note: All zigbee products need to be paired with tuya zigbee gateway for normal use
Feature
1.Zigbee wireless long-distance transmission:it needs to be paired with a gateway, otherwise the product cannot be used.
2.ZigBee Pairing, Fast Response
support zigbee 3.0 distribution network
3.Accurate Detection of Soil Temperature and Moisture
Keeping track of the flower's water needs and temperature status
4.Solar and Rechargeable Battery Powered
High conversion solar panel, high-power faster charge,Longer-lasting power supply with 1.2V*3 Ni-MH battery
5.App Remote Control
When travelling, view the health of your greenery in time
6.Share device with family
Create a smart home together with your family member
7.History Records
You can remotely view the history records of soil sensor usage in the
mobile app anytime, anywhere.
Specification
Power supply:1.2V3 Ni-MH battery(rechargeable)
Solar Charging Current:35mA
Temperature detection range:-10~60℃(14F~140F)
Moisture detection range:0~100%RH(Non-Condensing)
Electrical Conductivity detection range:20ms/cm
Temperature Detection Accuracy:0.5℃(Adjustable)
Moisture Detection Accuracy:5%RH(Adjustable)
Electrical Conductivity Detection Accuracy:3%FS 0.01ms/cm
Time span of detection:10min(Adjustable )
Communication protocol:Zigbee 3.0
Wireless protocol:Zigbee IEEE 802.15.4
Wireless distance:50M
Waterproof grade:IP66
Working temperature:-10~60℃(14~140F)
Working humidity:0~100%RH(Non-Condensing)
Product Size:86mm86mm*146mm
Packing list:
Soil Tester*1
Manual*1
Screwdriver*1
ZigBee Pairing, Fast Response support zigbee 3.0 distribution networkKeeping track of the flower's water needs and temperature statusHigh conversion solar panel, high-power faster charge,Longer-lasting power supply with 1.2V*3 Ni-MH batteryWhen travelling, view the health of your greenery in timeCreate a smart home together with your family member
