For Zigbee Smart Fingerbot plus Switch Button Pusher Touch Arms Fingerbot Works with Tuya Smart Life Control for Alexa Google
$91.63
Color: Black Fingerbot
  • Not Waterproof:This device is strictly for indoor use.Do not install on underwater or outdoor equipment.*Environment Limits:Avoid humid or high-temperature environment..
  • Obstruction Warning:Ensure the arm's path is clear.Obstructing the movement may cause the arm to detach or damage the internal motor
  • Battery Care:Powered by a replaceable CR2 3.0V battery.Replace promptly if the arm movement becomes weak or unresponsive
*Universal Compatibility. Effortlessly control buttons and switches on coffee makers, vacuum cleaners, and office PCs.
*Total control via the Smart Life app: Schedule routines, customize arm movements, and monitor device status anytime, anywhere.(Requires a gatewaycompatible with Tuya Zigbee ; 2.4GHz Wi-Fi compatible.)
*Modular & Replaceable Arms. Features a modular design with replaceable arms to fit any button type. 3D printing templates are also available for DIYers.
*Hands-Free Voice Control. Fully compatible with Alexa and Google Home—just say the word to activate your appliances.
*Powered by CR2 Battery. Reliable performance with easy battery replacement to ensure your smart home never sleeps.
Installation steps:
1.Clean: Wipe the surface of the panel.
2.Stick: Use the provided 3M double-sided tape.
3.Calibrate: Connect to the App and adjust the arm's movement for the perfect press.
4.Wait: Let it settle for 24 hours for maximum adhesion.
Safety & Usage Notice:
  • Not Waterproof:This device is strictly for indoor use.Do not install on underwater or outdoor equipment.*Environment Limits:Avoid humid or high-temperature environments (-10°C to 45°C / 14°F to 113°F)to protect battery stability.
  • Obstruction Warning:Ensure the arm's path is clear.Obstructing the movement may cause the arm to detach or damage the internal motor.
  • Battery Care:Powered by a replaceable CR2 3.0V battery.Replace promptly if the arm movement becomes weak or unresponsive.
  • Important: A Hub for tuya zigbee Required.""This device must be used with a Gateway compatible with tuya zigbee for App and Voice control
Why we recommend the Multi-Mode Gateway?
  1. Superior Stability:Ensures your Fingerbot stays online24/7without signal drops.
  2. Future-Proof:compatible with TUYA Zigbee, Bluetooth, and Mesh—ready for all your future smart home upgrades
