For Tuya Wifi for Zigbee Soil Tester Sensor Real Time Test Temperature Moisture Sensor Remote Monitoring for Flower Potting Tool
Features:
*Soil Moisture Monitoring: This soil tester is designed to provide accurate measurements of soil moisture levels, helping you maintain optimal watering for your plants and gardens.
*Temperature Sensing: Equipped with temperature sensors, it measures the ambient temperature, allowing you to understand the conditions affecting your soil and plants.
*Remote Monitoring: With its for TUYA compatibility, you can easily monitor soil conditions remotely via your smartphone, that your plants receive the care they need even when you're away.
*Construction: Made from high-quality ABS material, this sensor is built to withstand outdoor conditions, longevity and reliable performance over time.
*Compact Design: Its sleek and compact design (18*3.5*2.4CM) allows for easy placement in various locations, making it a versatile addition to your gardening tools.
Part Name:Soil Sensors
Material:ABS
Color:White
Package Content:
Soil Sensors*1
Note:
1. The real color of the item may be slightly different from the pictures shown on website caused by many factors such as brightness of your monitor and light brightness.
2. Please allow slight manual measurement deviation for the data.
